Question about Sanyo Microwave Ovens
Microwave error code
S1 code no heat
Main oven wont heat
Thank you for your post, Allison! I understand that you are having concerns with your microwave oven heating. This could be because of several factors, such as: loss of power to the microwave, a displayed error message or a faulty magnetron. Please ensure that your household power circuit breaker is not tripped and that your appliance is not displaying an alpha-numeric error message or code on your control panel. If you notice an error message please comment and let me know so that I can help you further. Otherwise, if you do not notice any errors and have sufficient power you are more than likely experiencing a faulty magnetron. The magnetron is the sole component that allows the microwave to heat. This is not a typical do it yourself repair so I recommend contacting a professional to confirm this and complete any necessary repairs.
Thanks,
Chris
Dec 18, 2013 | Electrolux E30MO65GSS Convection Microwave...
Microwave runs but will not heat(unit is approx. 5yrs old)
the problem may be with your thermostat check that ,and repair it
Jul 03, 2008 | Microwave Ovens
P80D20EP-Y6A not heating atall and has S1 symbol which ive never seen
reset the system: God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Oct 25, 2013 | Microwave Ovens
Microwave not working stating error 3 or error sensor or just coming on by itself. we have tried shutting down circut breaker
Hello
"ERR 3" means that the magnetron units have failed in the microwave. Food will not cook or heat up when the microwave is in use.
This code is different than "ERR 1" or "ERR 2" because with those the microwave is still operational. "ERR 3" means a complete failure.
The magnetron is the main source of power and heating in a microwave. Magnets work inside a magnetron tube to create the heat and voltage needed to cook items.
Bring the microwave back to the retailer or a repair shop for service. You may also consider purchasing a whole new microwave if the prices are cheap enough.
Oct 04, 2011 | Microwave Ovens
G E microwave model # JVM1190BY has reading sensor error or error 3 or at times just starts up when we are not even using. tried shutting circut breaker....whats going on
Hello
F9 error on screen and microwave won't heat
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high.
good luck .
please rate !
Mar 31, 2010 | Kenmore 60654 Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Sunbeam microwave doesnt work
i just brought my sunbeam microwave like two days ago. and it will not heat up
Jan 22, 2008 | Sunbeam SMW777 Microwave Oven
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven.  If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Oct 21, 2007 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Etronix
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
