Rca p46730wk 46 tv
There's no power whatsoever.Fuse is ok,someone told me that the power cable is know to give probles or the power supply.
  • sweetcorn Nov 18, 2007
    I have no power whatsoever. It always worked fine before we had a power outage in our neighborhood. I had a tv repair man here to fix it and he said he couldn't fix it here, charged me $62 for fifteen minutes, and said he would have to take it into the shop and it could cost 3 - 4 hundred dollars to fix it. I don't believe it could cost that much. Any ideas?
  • krasenicsjr Oct 03, 2008
    power wont come on for me either. makes a noise like it will turn on, then shuts down.
I have same set with same problem, no power. I just opened up the rear of the unit, where all of the circuitry is, and let loose a can of compressed air and cleaned off all of the caked on dust and dirt that had accumulated from the previous owner. And i mean let loose, make sure every surface you can see is spotless, and avoid blowing the dust up and ito the lenses, then I kept hitting the power button a few times, and it turned on and is working fine now.
I turned it on and off about ten times now and haven't had a problem.
Hope this helps.
Posted on Oct 03, 2008
Can anyone tell me what component CY5 on RCA 46" lcd power supply JSK4415-007 is? It small and blue like a capacitor. Says 220K on it.
Its a surge capacitor, the set will work without it but I would recomend relacing it, I'm guessing it looked something like this.
Nov 14, 2017 | RCA L46WD22 Television
46LA45R RCA 46" TV does not power up following a power loss
If a power loss someone needs to open set and see if when power came back it popped the line fuse, follow power cord inside to the fuse which it goes directly to.
Dec 11, 2012 | RCA 46 46LA45RQ LCD TV
Where is the fuse for my 46"RCAflat screen tv?
It should be located on the power supply board, just follow the power cord, it should lead you to the power supply board. You will have to take the back of the set off to access the fuse.
Jul 24, 2012 | RCA Televison & Video
I have an older 200x model Mitsubishi 1080i 46" rear projection TV that no longer turns on. When first powered up the power light on the front blinks in sequence to note that I have a bad power supply or...
Parts for older Mitsubishi are difficult to find. If you give me the complete model number I can check if the part is available online.
In the meanwhile please, try the two websites below.
Encompass Parts Distribution
PartStore.com
Feb 10, 2010 | Mitsubishi WT-46807 46" Rear Projection...
TV won't turn on, standby light just blinks 9times off and on
There is some problme in G Board (power supply board) in your Sony KP-46WT520 tv that is why standby light blinks 9 times.
If you are handy with electronics stuff repair and can test/ replace parts in circuit board then let me know to provide you more technical info to fix tv problem.
Feb 03, 2010 | Sony KP-46WT520 46" Rear Projection...
My RCA big screen tv shuts off and comes on by itself.
on top of the fuse it sounds like the power supplie is going bad
Dec 03, 2008 | RCA P61310 TV
RCA P46924 46" Rear Projector TV
First of all, we need to determine whether the power supply has a problem or if it is being told to shutdown because of a problem detected in the set. Are you familiar with electronics repair? Do you have a meter?
Dan
Sep 10, 2008 | RCA P46924 46" Rear Projection Television
No power
it is the power supply no doubt whatsoever
Aug 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture conversion
Hi,you have a bad convergence board.Try calling a tv parts house to buy one .They cost about $120.
Jul 22, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
518 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
