Question about Philips 19PR19 19" TV
Magnavox 19"PR19C1 - "This Should Be Your Next TV" continuous message on screen
My screen keeps showing "This Should Be Your Next TV" message on the screen.  It then starts listing the TV features.  Then goes on and describes each menu selection.  Then repeats this cycle continuously.
Pushing the buttons on the TV has no effect on stopping it.  My remote buttons have no effect on stopping it.  The only way to stop it, is to unplug it (even the power button doesn't work).
This started happening after my son kept pushing the channel buttons on the TV to try to change the channel.  Of course he couldn't change the channel because (unknowing to him -- he's little) I was recording using my VCR and the TV was in VCR mode.
  • jnrm Oct 28, 2007
    Problem Solved !!!  I found the solution below minutes after posting my problem.  Thank you !!!
    Hold Channel Up And Volume Up For 5 Seconds Or Hold Volume Up And Volume Down For 5 Seconds Or Hold Volume Up And Channel Down For 5 Seconds. That should do it.
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
  • 2336 Answers
SOURCE: Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Posted on Aug 01, 2008
SOURCE: Magnavox MODEL # HD1905 C121
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Posted on Dec 22, 2009
SOURCE: my Maganavox #19PSC5 0121 19''
I just found a solution elsewhere on this site...
In order to make the Demo Mode stop, you should press Volume Up and Channel Up together, and hold for four seconds. This worked for my mom's tv, I hope it works for you, mooone (and everyone else, too).
Posted on Jul 22, 2008
techjuli
  • 157 Answers
SOURCE: TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Posted on Nov 30, 2008
I have sound but no picture screen is black 19inch screen
I cannot say enough about this model. There is a bad capacitor or two in this set. You should be looking for a buldged cap at maybe 25 or 35 volts at 2200Mfs. Replace this and the next one near would be a 35 volt at 1200 Mfs. I have a question for you, if the model number is 42 MF, the screen is large. And yet you say it has a 19 inch screen. I'm not sure if you have the large TV or the small TV. The answer I give you is for the large screen. Hope this helps you! Thanks for asking and show a few hands of support!
Oct 07, 2010 | Philips Magnavox 42MF521D/37 Television
After Power outage - picture is larger than screen
This TV also should have similar facility like 19" Tv. Try the menu, it may be in different name or classification. I do not suspect circuit fault. If you can access service menu code you can try. Better take assistance from service center. If you access service menu, do not for get to note down the values in each and every step.
Apr 30, 2010 | Philips 19PR19 19" TV
My Magnavox 17in LCD TV (17MF200V/17) shows message ''Attention OSD Main Menu locked. cannot use any functions on tv. i.e., volume , menu, etc
It means that some kind of parental control feature has locked you out of the On Screen Display menu. You will have to consult your manual (possibly online) to figure out how to reset the password.
Although it is possible some other kind of malfunction could cause you to lose menu control, this is the most likely cause.
Oct 07, 2009 | Televison & Video
Magnavox tv problem a green vertcal streak on rt side
Dickson do you have a speaker next to your tv anything magnet will change color it may need demagnatised
Maxol your tv more then likely has a bad picture tube or you have a shorted transistor for green output shorted on CRT board.
ThankYou for using FixYa. Have a Nice Day.
Dec 28, 2007 | Philips Magnavox 27MS343S 27" TV
Magnavox tv
Hold both vol up & chan up on front of set for at least four seconds.THen demo mode will release.
Oct 03, 2007 | Philips Magnavox 27MS343S 27" TV
My 19" Magnavox won't come on.
LOL its in a demo mode man!! simply hit the menu button on the original remote and go to the special settings and turn them off. If it still does not work, then the painter or the Microprocessor Ic Needs to be replaced.
Sep 09, 2006 | Philips Magnavox 27MS343S 27" TV
Philips 19PR19 19" TV Logo
247 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
