Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag front load washer leaking water from detergent dispenser
3 year old machine just started today. I cleaned the tray of caked on detergent,machine is level,turned the water valve down a little,cleaned the upper water holes with a tooth brush, water still flows out the front when machine goes into wash cycle. I noticed when I pulled  the tray out there is a drain that runs the water into the drum,could this be starting to stop up. Feels like there is a plastic sleeve in there. If this needs to be cleaned how do you get to it and is the other end connected to anything?
I have a whirlpool duet sport and it was leaking from the detergent despencer. Since the dryer sitting on top of the washer I didnt want to take the top off. I took the control panel off then took the front panel loose and let it hang a by the seal. I could then see the tube going from the detergent despencer to the tub. I unclamped the hose and wiggled it out of the lower hole. I found a sock in the tube. I removed the obstruction and reassembled the washer. Works fine, PS this advice is free other jackholes want 30 bucks. Have a great day and good luck you can do it!
Posted on Nov 15, 2011
    Scholar:
  • 146 Answers
The other end of the dispenser to outer drum hose only connects to the outer drum and if you remove the top cover of the machine, you will see it clearly. You can unclamp the hose from the bottom of the dispenser and feel inside the hose for any obstruction. Do not remove the hose from the outer drum. Pour some hot water down the hose and squeeze the hose from top to bottom to remove build up of detergent and softener on the inside walls of the hose.
Posted on Nov 05, 2007
How to fix leak from soap dispensor
I assume you have water coming out of the dispenser and running down the front of the machine. You probably have a build up of soap powder in the water inlet and it is restricting the flow and backing up.
Soap powder is only partially soluble in cold water and a residue of undissolved powder builds up over time, one of the reasons I use a liquid detergent. Remove the dispenser tray, it should pull out fairly easily with just a little resistance. Try and clear any blockages, hot water is best as it dissolves better. Clean the tray you have removed and re-assemble.
Dec 07, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Water leaking out of soap dispenser
I have had this happen. I have taken the dispenser tray out and cleaned the area where the water and the detergent will flow into the washer at. This area had gotten some gunk build up, once I cleaned it, it has not leaked since. Now I just routinely look at this and make sure that it is clean. Hope this helps you.
Mar 06, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
My Kenmore Elite front load steam washer started pouring water from the detergent dispenser
It might be needed to remove the panel to get access to the tubing , please check this link for tips to check this out: dispenser
Jul 05, 2012 | Kenmore Elite Washing Machines
Dispensers is not releasing detergent dishes are still dirty
TAKE OUT THE DISPENSER TRAY AND CLEAN ANY BUILD UP OF DETERGENTS ALSO CLEAN OUT THE TRAY HOLDER .
Nov 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water and detergent are in the bin after wash cycle
check to make sure water lines are not clogged and detergent tray is not caked up
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Water leaking through soap dispenser drawer
OLDFIXER was exactly right ! I had water gushing out of my LIQUID detergent tray. I removed the tray by pushing down on the flexible tab at the back of the tray and when I had the tray out I discovered A LARGE AMOUNT OF DAMP powder detergent caked up on the inside. I removed it all and sprayed some hot water inside AND ITS COMPLETELY FIXED !!! GOD BLESS OLD FIXER.
Apr 27, 2008 | GE WSXH208A Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
722 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
