Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Flickering, sparkeling, ghosting, you name it. Related to electricity in house?
I had no problems with this monitor for over a year. I recently moved and within a few weeks the image suddenly developed purplish vertical lines (not all the way from top to bottom though), dimmed colors, extreme ghosting, and a loss of sharpness. I sent the monitor back to samsung and they sent me a new one. Within hours of starting to use the second one it started flickering on and off from time to time. It also had some pixels that turned differnt colors which made it look like the screen was sparkeling. It would do these two things on and off, and sometimes worked fine. I decided to unplug it though out of fear that something permanent might happen to it like the first one. My best guess is that the problem has something to do with the electricity in the house. It is old and the electrical outlets have not been updated. They don't even have grounds. Please let me know what the problems could be realted to. Thanks!
  • thedeep Feb 24, 2008
    I just solved the problem the other day. I found the solution on another forum. I went into my graphics card settings and checked off "reduce dvi frequency on high resolution displays" and that completely ended the flickering. That said, this monitor is obviously a finicky one and if your card didn't have that setting then i suppose you would have to send it back. I have a Radeon 9600.
  • aardvark2008 May 04, 2008
    When I boot up my screen starts flickering, very slowly at first and then speeding up until it returns to normal. Sometimes I have to disconnect the electricity to make this happen. Screen sometimes remains totally black
No, it is not the electricity in your house, I had the same problem. Send it back to Samsung and get a new one. I have had to send my monitor back 4 times!
Posted on Feb 24, 2008
My campaq desktop monitor 7540 is flickering horizontal direction
Try a different CRT monitor on your computer.
Try your CRT monitor on a different computer.
See if the problem "moves" to the other computer,
or whether your computer has problems with *ANY* monitor.
Dec 27, 2013 | HP COMPAQ 7540 CRT Monitor
Monitor Flicker
Hello, my name is Chris. This is a really simple fix. Please make sure that your VGA card (video card) is pushed in on the motherboard. Even if it's a PCI Video Card. Still check. And make sure it is screwed in as well. If it's none of the above, than your motherboard is fried.
Mar 04, 2009 | E-Machines E17T 17" Flat Panel LCD Monitor
FPD2185W Gateway Monitor
its still ur power chck for swollen fillter capacitors
Oct 17, 2008 | Gateway FPD2185W 21 in. LCD Television
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
I have noticed recently that the screen words flicker.
If the monitor is less than a year only, then your best bet is contact the manufacturer for warranty support.
Jun 14, 2008 | Acer AL2017 20" LCD Monitor
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
Hello out there ... I have a 2yr old HP w19e monitor which just wants to shadow all text & images from desktop to emails, pics & everything else. I can't get simple solutions on any comp help at...
It sounds as if you have "ghosting". Has your monitor been moved recently? Do you have any electrical cords running over or on the monitor cable? have you changed the video cable to see if it still does it? I have seen this issue be solved by using a good quality VGA cable, cheap ones usually ghost.
Let me know =)
Mar 31, 2008 | Computers & Internet
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
225 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
