Question about Philips 60PP9352 60" Rear Projection Television
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
I can converge colors up and down but not left or right. Color is way outta wack on my 56 inch pilips rear proj tv. HELP
You have to adjust your screen controls - red green and blue
Posted on Feb 22, 2008
    President:
  • 4,402 Answers
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 19, 2007
My color focus is all outta wack. maybe its the a convergence problem?
depends on exact model number but a kit (someone like TV parts .com) sell a kit for this---individual parts are usually cheaper but some real soldering etc is involved as set uses two chips if it is a older rear projection set and does NOT use a lamp but has 3 picture tubes.
Oct 14, 2012 | Televison & Video
Need help with tv
U replaced 2 STK convergence ICS right?U check all the resistors too,and replaced it right?The convergence problems usally reset it back by it self.If all convegence parts are replaced correctly,and finish.
Mar 17, 2010 | JVC AV-56WP74 56" Rear Projection...
Color blue will not adjust on crt color conergence adjustment , picture on tv is double with blue on right side, auto/manual mode , the color blue will not adjust on right or middle side from side to side,...
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | JVC AV-56WP74 56" Rear Projection...
Sony TV rear proj works but color is blue
Problem : Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Colors are separated on the top from the left to right
Probably the color convergence is off. I had a similar problem. Have you tried the magic focus button yet? That is located at left in the small front control panel. Power on TV, wait 20 min (according to user guide), then press the magic focus. If that doesn't fix the problem, you could try the service mode alignment procedure. But that's a little trickier. I don't have a link handy for that procedure right now, but will look for it if magic focus doesn't re-align your color convergence.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
JVC 56 inch projection AV-56WP74 red color not aligned
I have the same tv set and about 4months ago Ihad the IC STK392-110 replaced. I was told that it was the most common problem with proj. tvs. It did solve the probem until last night when I went into the menu to change a audio setting and stupiditely accesed the convergence setting and decided to do an auto adjustment which mesed up my beutiful HD picture. Now I have the red out of alignment ad even after I did a reset and multiple manual adjustmets it is still off at the top and bottom af my screen.
Dec 27, 2008 | JVC AV-56WP74 56" Rear Projection...
JCV HD Convergence Problem.
Replace both convergence IC's......Please confirm Model #
off back of TV and I will help you step-by-step....Requires
above-average soldering skill......................T.
Nov 18, 2007 | JVC AV-48WP74 48" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
