Question about Cuisinart ICE-45 1.5 Quart Ice Cream Maker
No power to the unit
I just purchased this machine and can't get it to turn on. (no power)
  • 8,596 Answers
Make sure the bowl and mixing paddle are in correct place, and that lid is locked into place. Turn dial to on and try again. If this fails to resolve, replace it -has a 3 year warranty.
Posted on Dec 09, 2008
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
8756 machine freezing up and icecream to thick what can it do to change problem
You can adjust the viscosity.
In soft serve and frozen yogurt machines, the logic board X36641SER2Refurbished Gen 2 Logic Board This item is sold with exchange...measures the viscosity of the product by monitoring the amp draw of the beater motor. When the machine reaches the set point, it cycles off and the product is ready. In auto mode, you can only adjust product viscosity, temperature in the freezing cylinder is not monitored.
The power board measures the amp draw. L1 power supplied to the beater motor goes through the power board on the beater terminals. Single phase and three phase units use the same Softech control, so the power board allows for different amp draw ranges. A jumper on the power board determines the amp draw range. Place the jumper on the pin that corresponds to the amp draw of the beater motor when the product is at the desired viscosity.
Setting Viscosity Adjustment
1. Place an amp probe on one of the L1 leads on the beater terminal on the power board.
2. Turn the viscosity adjustment screw to the "MAX" position.
3. With the freezer properly primed, press "AUTO".
4. During the freezing process, draw samples and inspect the product appearance. When the desired product viscosity and appearance is achieved, note the beater amperage.
5. Press "AUTO" to cancel the refrigeration cycle.
6. Using the chart, set what range the beater motor amperage falls into and place the jumper on the corresponding pin.
Viscosity Control Chart
2.4 pin - 1.2 amp to 2.4 amp
5.0 pin - 2.5 amp to 5.0 amp
8.0 pin - 5.7 amp to 11.2 amp
7. Press "AUTO". When amperage reaches the noted draw, turn the viscosity adjustment screw SLOWLY until the unit cycles off.
8. Draw several samples to verify the product and amperage when the machine cycles off remain consistent.
Adjusting Viscosity
To increase viscosity, or make the product harder, turn the dial clockwise towards maximum. Important: The dial only turns a limited amount if it stops turning do not force it.
To decrease the viscosity, or make the product softer, turn the dial counter-clockwise towards minimum. The dial only turns a limited amount do not force it once it stops.
We recommend you only turn the dial about 1 hour on the clock, at a time. Once you have made your adjustment, pull the handle to start a new cycle, when the machine cycles off check the product again.
adjusting viscosity on taylor frozen yogurt machine-5jpt2eusobswb402obrm5sjf-2-0.png
Jun 06, 2017 | Ice Cream Makers
Gongly soft ice cream machine won't work. Beeping sound when power is turned on. What is the problem?
manual control soft ice cream machine, View carpigiani ... > Product Categories > Soft Ice Cream Machine
manual control soft ice cream machine,US $ 0 - 1000 / Unit, Air-Cooling, CB, CE, ... Brand Name: GONGLY; Model Number: BQL-838; CERTIFICATION: CE/CB, ...
Machine glace italienne - YouTube
? 6:48
Jan 3, 2011 - Uploaded by TvSTORE
Machine glace italienne TvSTORE ... Jin Li Sheng Fry Ice Cream Machine Fried Ice Cream Machine Fry Ice Pan Machine ...
Hot Sale Jin Li Sheng BQ322 BQ332 Soft Ice Cream ...
? 1:14
Jan 14, 2016 | Ice Cream Makers
How do I get the beater out of my soft serve ice cream machine model #152 12
On the front of the machine on both sides the dispensing handle there are large thumb screws (I believe 2 on your unit). Empty the product from the machine then turn the thumb screws to the left to take them off. The screws hold the face plate on the front of your machine. You will then be able to remove the face plate from the front of the unit. The beater will be in the freezing cylinder behind the face plate. You will be able to just pull it out.
May 22, 2015 | Ice Cream Makers
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page.
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
Get rid of this unit it is too old to repair.
Jul 10, 2009 | Taylor 632-33 Ice Cream Maker
Emerson IM90 Portale Ice Maker
My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
Aug 23, 2008 | Ice Cream Makers
Gets only cool not cold
the thermostat is supposedly right below the BLACK switch knob of the unit.
it should look like this if you open the unit up.
but before you open the casing, try to refer to CuisinArt's warranty terms even if you lost the proof of purchase for the unit.
good luck
Jul 27, 2008 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Open Questions:
Cuisinart ICE-45 1.5 Quart Ice Cream Maker Logo
102 people viewed this question
Top Cuisinart Ice Cream Makers Experts
Greg Cann
Greg Cann
Jay Finke
Jay Finke
Oloyede Monsuru
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
