Question about Car Audio & Video
No Sound From My Amp!
Power Acoustik PS2-1200
I've had a full audio system in my car for the past three years, including 1 two channel Power Acoustik amp that has recently stopped working.  The power led is always green but I never have sound coming from my two 12's.
For about two weeks it would constantly stop thumping every now and then, I'm guessing when a braked or acelerated, every time there were G's.  Well, it stopped working at a gas station, I turned around and hit the amp from fustration, and it worked!  Only problem is that five minutes later it stopped working again and never again thumped!
I've swapped the RCA from my high's amp to the PS2-1200 and nothing.
My two amps both have common ground and power coming from a capacitor.  I've also opened the amp, but haven't seen anything obiously wrong with it..
Please help!
  • Anonymous Oct 09, 2008
    it torn on but no audio
    Novelist:
  • 111 Answers
I am assuming the amp is not under warranty, if it is, rma it... if not, you have nothing to lose from trying this.
hitting it and having it work usually means something is loose or broken, remove the case and extract the circuit board.. clean all parts thoroughly using a good electronic or contact cleaner, i use crc qd electronic cleaner as it is cheap and available at most auto supply stores, just make sure whatever cleaner you use is not industrial duty and is plastic safe.
after the entire thing is cleaned (coils, caps, anything resembling dust), check with a magnifying glass for any broken solder joints, you can also very lightly touch components and see if they move.. this sounds like either broken solder joints, extremely dirty contacts, corrosion, or dry caps.. you can usually locate dry caps by looking for corrosion around the cap and discoloration on the top of the cap.
hope this helps, and hope you get it running; the ps2 amps are pretty nice when it comes to accurate sound reproduction.
trin
Posted on Nov 16, 2007
I had the same with a power acoustik 2000 watt... power is coming on the green light and no sound. i took it to an electronics store to be repaired...... the guy told me this amp is a piece of **** throw it away.. and so i did... the problem was solved.. i now have a rockford fosgate 800 and it rocks 2 pioneer 12".
Posted on Oct 19, 2008
2000 dodge ram 1500 trying to fine the horn what size is it on please
[PDF]PDF (23MB) - Power Acoustik
www.poweracoustik.com/pa2012/manuals/2014-PA-catalog.pdf
RZ4-2000D. 2,000. 2 x 500. 4 x 250. 4 x 190. 11". -. RZ5-2500D. 2,100. 300 x 2 + 600 x 1. 150 x 4 + 600 x 1. 100 x 4 + 400 x 1. 12.25. Included. RZ1-1500D.Missing: lfa1 ‎dodge ‎ram
Have Audio Questions? We've Got Answers! [Archive] - DODGE RAM ...
www.ramforumz.com/archive/index.php/t-60713.html
Sep 3, 2010 - 100+ posts - ‎68 authors
I'd not try that as the stock amp just won't have enough power at the sub .... Or will any cheapo wood box work fine? ..... I have an 03 ram 1500 QC with the infinity system...... I just purchased a new 2010 Dodge Ram Big Horn Crew Cab Long Box with the 6... 1 Power Acoustik ONV1-2000D and ONV4-1200Missing: lfa1
2 Ohm, 4 Ohm, 1 Ohm, what's the difference? - Car Stereo ...
Dec 25, 2015 | Power Acoustik LFA1-2000D Car Amp
Boom audio, blown fuse
Fill the air with sound from this Boom!™ Audio Boom Bagger Kit. This complete audio kit provides the latest in Harley-Davidson® audio components. When installed, the increased power of the amplifier provides the speakers with a clean signal, and a custom equalization is available to further optimize the performance of the Boom!™ Audio speaker system.
  • 4-Speaker Ultra Boom!™ Bagger Kit
  • Ensure maximum output of your audio system with the recommended High Output Charging System P/N 29900028
  • Dealer Digital Technician software update is required
  • Dealer installation is recommended
  • Kit includes Boom!™ Audio 6.5" fairing speakers, Boom!™ Audio 4-channel fairing-mounted amplifier, amplifier mount and wiring harness
  • Speakers feature two-year warranty
  • Stop by a participating dealer to interact with a unique audio display that lets you simulate how your bike will sound with Boom!™ Audio upgrades. Contact your local dealer for details
From: http://www.harley-davidson.com/store/boom!-audio-boom-bagger-amp---speaker-kit-pa-08-76000411--1
Jun 11, 2012 | Harley Davidson Motorcycles
I have a power acoustik 0v2-300 2 channel amp i just wanna know can i bridge it
Most amps will show right on the amp by the speaker wire terminals if it is bridgeable.
Good luck !
Jan 28, 2010 | Power Acoustik GOTHIC OV2-300 Car Audio...
I have a rockfored fozgate 400w amp it was
Look for popped Capacitors. These are the tiny cans that are on the circuit board. They usually buldge out on the top and leak white paste.
Good luck and i hope this helps.
Jan 26, 2010 | Power Acoustik LT-980/2 Car Audio...
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Lt960-4 power acoustik Amp 4 channels mono
it can be used as a bass amp. if each pair of channels is bridged then you will basically have a 2 channel amp. just be sure to set the x-over's to lpf for subwoofers. I checked the power ratings, and bridged at a 4 ohm load will give you 250 rms watts per sub, so thats enough to run most 10's or 12's. there wasnt a rating for a 2 ohm load, but your amp should support it.
Aug 03, 2009 | Power Acoustik LT-980/2 Car Audio...
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Oct 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Power Acoustik Area 51 Amplifier
I havthe same amp. Try moving youry ground t a different location. that seemed to help me when i was brigging mine.
May 08, 2007 | Power Acoustik Area 820x2 Car Audio...
Car Audio & Video Logo
245 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
