Question about GoVideo HT2015 System
DVD drawer will not open
My Sonic-Blue GoVideo HT2015 dvd drawer will not open. Please help with a solution.
I don't know how to begin to solve this problem.  Thanks,  Yvonne
Re: DVD drawer will not open
I had the same problem with mine and what I had to do was take off the outer case and unscrew the 4 screws that hole down the dvd player in side the unit and left them out.
For some reason it was binding on the dvd player and would not let the tray slide out.
Hope this will help you out off the mean time.
Posted on Feb 07, 2009
0 characters
3 Points
Dvd or cd are not open
I think you are saying that the CD/DVD drive drawer will not open?
Most drives have a tiny hole above the drawer. You need to straighten out a paper clip ,then poke it into the hole. This should release the drawer catch and you can open it by gently pulling. It may be jammed as a disk was not properly seated inside.
Check on My Computer that your computer recognises the CD/DVD player is there.
Mar 03, 2014 | Panasonic SC-PM39D System
My HT-z310 dvd player does not read when i put dvd in
Try manually pushing dvd drawer in after pushing open/close. I opened mine up and noticed the dvd is not spinning - I don't think the drawer is completely closing over. BTW this is not a permanent fix - it doesn't work all the time.
Apr 18, 2010 | Samsung HT-Z310T Theater System
The dvd drawer will not open on Bose 3-2-1 system. When you push the button to open the dvd, the display say ''opening'' but it does not open. There currently is a dvd inside.
That happens when you close the drawer instead of pressing the close button  you can skip gears and it would have to be taken apart and re-calibrated.   Sometimes it is just a glitch that you can over-ride using a straight pin into a small hole on the front  (assuming this uses a drawer).
Nov 09, 2009 | Home Theater Systems
DVD drawer will not open on Zenith
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
Aug 05, 2009 | Zenith ZHX-313 System
DVD drawer does not open and the whole system doesn't work but it
defective unit, happened to me. i threw it out the window after fighting with it to get my dvd of american history x out of it, i then pulled my old dvd player out and resumed the movie. i recomend buying a new dvd player, or bust out that dvd player you got in the closet covered in dust
May 04, 2009 | Home Theater Systems
Dvd drawer will not open
Manually open the tray. It's possible that you have a dvd stuck in the drawer because it wasn't fully seated. Look at at the front of the drive and you will see a tiny hole. Take a paper clip or safety pin, stick it in the hole and push. You will see that the drawer will pop out and you can retrieve your stuck dvd. Thanks for using
Jan 27, 2009 | Progressive Computer JSI 6 spkr. Home...
Bose 321 DVD System
I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
Dec 10, 2007 | Bose (321GS) System
Dvd locked
Hello, try pressing stop and eject for 5 seconds. If you need more info please advice. Arpi
Jul 26, 2007 | Sony DAV-S888 System
Home dvd video player
in DVD mode, open drawer, remove disc, close drawer,
press "sub woofer" for 5 seconds
Jan 17, 2007 | RCA RTD160 System
GoVideo HT2015 System Logo
108 people viewed this question
Top GoVideo Home Theater Systems Experts
Gyula Lacz
Are you a GoVideo Home Theater System Expert? Answer questions, earn points and help others
