Question about Dell Inspiron 2200 Notebook
AC Adapter My Inspiron 2200 is not acknowledging that the ac adapter is plugged in. The original one was plugged in and the message "please plug in your pc" came up...then it hibernated. I could not get it to turn on again. I bought a new one, and it seems to only charge the battery when the computer is hibernating; when I turn it on it still does not acknowledge the adapter and drains the battery. I've tried wiggling the cord around, but that doesn't help. Any idea what could be wrong? I spent $50 on this new power cord....great :(
  • Anonymous Nov 12, 2007
    I have the same problem. I have to pull the cord to the left and pray no one touches the laptop. I was told I have to have it repaired by Dell themselves. It's something with the mother board which when the laptop was under warrenty, it was replaced twice!!
  • 83 Answers
Hey thats one of two things your (internal charging unit) if so your SCREWED if not its the sowtware issue witch means you gotta tweak the settings especially if you just upgraded your OS if tweaking doesnt work then re-install your OS then set your OS setting Correctly to the best of your knowledge have fun...it take a bit of patience and a couple hours i had the same prob.....seeya
Posted on Oct 28, 2007
Have a dell inspiron with original ac adapter and battery. i get error message saying that the AC adapter cannot be determined is not recognized by dell and need a dell 65W AC adapter. I have the...
The adapter could be faulty or has failed slightly and is below the operating limits. This means you probably need to replace the power adapter.
Nov 01, 2010 | Dell Inspiron 1501 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 2200 will not power on
Check your AC adapter for an LED showing it is getting power from the wall. Make sure you have no external devices connected, then try booting with just the AC adapter, next, just the battery. If still nothing, then your motherboard is probably bad.
Apr 23, 2010 | Dell Inspiron 2200 Notebook
Dell inspiron 1501 cannot indentify ac adapter
try this first. drain the flea power. remove batter and ac adapter. press and hold on the power button for 10 seconds. plug back ac adapter and battery. go online to http:support.dell.com then download the latest bios update.
once you reach the dell support site select on support for home users. then drivers and downloads. enter the service tag.
when the list of drivers and updates are listed make sure you selected the correct operating system. look for the BIOS then download it via browser. (do not download the manager)
after the download run or install the update.
If all fails. try a diff ac adapter if same problem message appears then replace the motherboard. else replace ac adapter.
Mar 30, 2010 | Dell Inspiron 1501 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Inspiron 1318 but when I connect the ac adapter cpu 100%
It is a possible AC adapter problem. However please try to download the BIOS firmware update from Dell's website and see if problem exists. If it does, then try using another AC adapter (preferably the same model and make) and see if the same problem occurs. Please reply if same issue occurs.
Aug 10, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 2200 laptop cannot turn off battery calibration error message after running this program.
How to skip:
1. Turn on the laptop.
2. Go into reclabiration.
3. when it says "Please remove the AC adapter" take ALL leads out of it.
4. Leave for about 10 mins.
5.Turn it off.
The battery reclabiration message should be gone.
If not, Your battery needs to be replaced.
Jun 23, 2009 | Dell Inspiron 2200 PC Notebook
My dell Inspiron 1318 laptop's battery is not charging.
check power supply see if its putting out voltage to laptop
Mar 29, 2009 | Dell Latitude C640 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
AC adapter for dell laptop inspiron 2200
You can order the part from this link
Dell_PARTS_ADAPTER
Once you open the link scroll down and select the second adaper in the list
60 Watt 3 Prong AC Adapter with 3-ft Power Cord for Dell Inspiron 2200 / Latitude 110L Laptops
May 20, 2008 | Computers & Internet
Dell Inspiron 2200 Notebook Logo
71 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
