10 yr old GE side by side: freezer is leaking water daily, from bottom. There is a large amount of ice built up in bottom of freezer. Leak seems to be coming from inside and accumulating in bottom, then running out from underneath the freezer door and onto my tile floor (which now has a warped sub-floor that needs to be repaird!) Can you please help me? - Single Mom, Frederick, MD
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
