Question about Dishwashers
Dish washer When i turn on the dishwasher as soon as it cycles i have water coming out of the air vent on top of the sink. it is connected to thegarbage disposal
Also, some Garbage disposal models have a plug that needs to be removed before hooking the dishwasher drain hose to it. Be sure this plug is removed.
Posted on Nov 10, 2008
  • 74 Answers
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Posted on Oct 28, 2007
Have a Samsung dishwasher DMS300TS displaying E3 error. Manual says blocked drain but all is clear and impeller moves freely. Any clues?
Do you have a drain vent that goes up to your Counter/Sink next to your faucet? It's a called an Air Gap or dish washer drain vent. Sometimes those get clogged.
Also, make sure your drain hose does not get pinched when you move the dishwasher back into place. Hope that helps
Good luck
Mar 11, 2018 | Dishwashers
Dishes not coming out clean. Dish washer 3-4 years old, never serviced
The key ... let me say that again ... The Key to clean dishes is hot water in your machine. Second is the cleaning compound you use. I suggest you get hot water in your sink before you turn on the dishwasher. I think you will see a big difference.
Thanks for your interest in FixYa.com
Mar 30, 2011 | Dishwashers
My dish washer leaks water
The hose from the air gap on top of your sink to the garbage disposer is plugged.or kinked probably.Unless you have a new garbage disposer and the plug wasn't knocked out at the dishwasher drain connection
Jun 23, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Not cleaning dishes properly
Hi and welcome to FixYa. I am Kelly.
Dirty dishes post cycle are a sign of draining problems however this is a list of what it could be.
1. A partially clogged drain
2. The timer motor is not functioning properly
3. A broken or worn pump impeller
Here is what you need to do:
Check your entire drain system. Start at the final outlet and work your way backward to the motor pump connection on the dishwasher.
Suspected areas are.
a. The sink connection outlet is clogged (this can be inside a garbage disposal.
b. The air-gap is clogged in the very top part of the air-gap (Usually located on the back of the sink and is around 3 inches tall) Remove the cover, unscrew the top nut and check under the horse shoe bend inside the plastic top for obstructions. Clean as needed)
c. There is debris on top of the the motor pump housing blocking the inlet drain. (This would be inside the housing of the lower wash arm on the very bottom)
d. The motor pump outlet drain port is partially blocked. (only accessable from the motor pump exit hole after drain hose removal.)
A partially blocked inlet tub drain to the motor pump would also explain your soap dispenser problem. Additionally you would have spotted dishes post cycle.
When the drain is partially blocked some models use the float level switch in the tub to control the advancement of the timer. If the water does not drain the motor pump continues to run and run and the cycle does not advance until the tub is drained and the float switch senses same. i.e extended cycle
Thanks for using FixYa.
Kelly
Apr 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I replaced a disposal and now when I run the washer cycle the used water shoots out the drain that is on top of the sink. It didn't shoot out that drain while the old disposal was working and the dishes...
The new disposer has a plug inside the dishwasher nipple that you must knock out. The dishwasher hose nipple is plugged so water won't leak out if you don't have a dishwasher connected. You must take a flathead screwdrivers and knock out the plug inside the nipple with a hammer or something. Make sure you don't leave the plug inside! The air gap is designed to prevent water from siphoning back into the dishwasher. With the disposal's drain connection blocked, the water exits through the air gap!
Feb 15, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
My Bosch shx46A05UC no longer will drain.....it
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Cheers!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
My stainless steel dishwasher smells
You need to check to see if the drain line runs from the dishwasher pump to either a "T" on your kitchen sink drain or if it connects directly to the garbage disposal. Either connection is okay. However, water can run downhill from either connection to your dishwasher. To prevent dirty water from your sink or garbage disposal from running downhill to the dishwasher, you may have to install a dishwasher air gap. This can be purchased at a appliance parts store or a home improvement store like a Home Depot or Lowes. It is a "Y" shaped device that should be installed above the dishwasher drain line connection under the sink. As water will not run up hill, you need to make sure that the Air Gap is installed higher than the drain line's connection under the sink. "The Air Gap device should be mounted as high as you can under the sink."
Aug 22, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Ge top load washer WSERE526FOWW
Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Sep 11, 2008 | GE Washing Machines
Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Dec 31, 2007 | Dishwashers
Dishwashers Logo
190 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
