Question about Fellowes 220C-2 Shredder
Shredder motor sticks
Motor sticks and won't run when it gets warm
Hi we had the same problem it was solved by changing the small nylon gear wheel in the gearbox and regreasing the same hope this helps
Posted on May 06, 2009
    Scholar:
  • 102 Answers
Call Fellowes Customer Service 1-800-945-4545
Posted on Feb 22, 2008
Motor won't run.
The problem could be with the switch that powers the motor or the brushes on the motor itself may be worn. Also look for bad connection in the wiring.
Sep 17, 2017 | Husqvarna Huskylock Computerized 910
Bryant Central AC
Hello, if the motor runs after manually starting it the capacitor is bad and will need to be replaced. If the motor keeps cutting out after a while the motor is overheating and will need to be replaced. The smaller line should be warm to the touch , the bigger line with insulation should be cold and slightly sweating. If both lines are room temp the compressor is not running.
Jun 30, 2012 | Heating & Cooling
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
My 19991 GMC Sierra 5.7 litre engine runs great when its cold but after 5 minutes it is very slow in accelerating . When I take off first thing in the morning I could easily smoke the tires but as soon as...
while motors warm up the computer supplies information so the motor works well. After it warms up the computer is guided by sensor information. It sounds like a sensor is going bad. Try to get a scanner reading which might show which sensor. The two main imputs to fuel are oxygen sensor and temperature sensor. Real common for O2 sensor to go bad.
Apr 21, 2010 | 1991 GMC Sierra
Replaced motor,now won`t spin
Something is locked in the transmission--can you turn the inner tub manually? Also, try to turn the driven pulley (the motor and belt driven). The problem could be anything from a seized bearing to a broken gear. Don't keep trying the motor while things are locked up, you could burn it out.
Aug 18, 2009 | Washing Machines
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
Heater blower problem
under the hood of the car on the passenger side you will see a round motor sticking up.thats the blower motor there should be 3 screws holding it in place and one plug to unplug.you lift the old motor out and put the new one in in its place
Jan 13, 2009 | 2002 Hyundai XG350
Fellowes 220C-2 Shredder Logo
178 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
