SOURCE: Red Led Flashing
If you haven't already found a solution to this problem, it is more than likely a failed fuse. If you are comfortable with the high-voltage electronics in your TV and are handy with a soldering iron, you can attempt to locate and repair the fuse(s) yourself. However, the fuse is more than likely failing because of an additional problem. It all depends on which fuse failed. Can you get back to me?
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Five blinks - AKB
up screen A2 slightly.
