Waffle iron model 265 instruction manual needed. What does light indicate? When it goes out is the iron pre-heated enough to put in the batter?
SOURCE: waffle iron light goes on gut does not heat up...
The most common reason for not heating up is because of a blown thermal fuse.
Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on.
When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
SOURCE: Toastmaster waffle maker - have no manual
http://dl.owneriq.net/4/4d7525b4-d3f8-43f8-b5a9-03673112a1e9.pdf
Here it is, you may have to join but it is free!
SOURCE: Missing manual for Toastmaster twb4 waffle maker
Could not find an official Toastmaster site but found a manual where you have sign up for free?
http://kitchen.manualsonline.com/manuals/mfg/toastmaster/twb4bel_and_twb4bel.html?s=fpw
SOURCE: Repalcement plates for Model 270A Toastmaster Waffle Iron?
Actually I have a Toastmaster 270A waffle iron. It is much better quality than the later toastmaster models, and it is basically identical to the Black & Decker model G48TD, which is still sold. You could get plates from Black & Decker. The entire iron sells for $50.
