Question about Hoover Vacuums
Hoover Bagless Windtunnel - Self Propel feature not working
I have a Hoover Bagless Windtunnel that has stopped self propelling.  It self-propels forward, but not when I pull back on it.  The self-propel handle seems to be loose and goes up and down when I pull back.  I have cleaned out the bottom of the vacuum and all the belts are intact.  Can you help me troubleshoot this problem.
  • Aces7879 Dec 19, 2007
    I have the opposite problem - rolls easily when pulling back but will not self-propel forward. Any clues? And any way to prevent this from happening again after replacing the cable ... if that's what it needs?
  • Anonymous Mar 29, 2014
    Any ideas
I have the same problem with ours. If you lift the vacuum by the handle it breaks the lever on the transmission. You can find a replacement cable and lever on line for about $16.00 it is somewhat involved to repair but can be done by someone with mechanical ability. You can try and find a repair shop but be careful, they sometimes tell you the part is not available and try to sell you something else. I think they should be able to do the job for aprox. $80.00, but they may want more. I did it myself plus the height adj. knob for $24.00
Posted on Nov 25, 2007
Why won't hoover wind tunnel self-propel?
Hi there! The self-propelled feature is controlled by a belt. Check the belts on your Hoover Windtunnel by following these quick steps.
1. Recline the handle. Lay the cleaner fat and flip it over to expose nozzle base.
2. Remove the screws attaching the nozzle.
3. Check that the belts are not broken, stretched or damaged.
Replace the belts if they are damaged. Hope this helps!
Jul 04, 2014 | Hoover Vacuums
Hoover Windtunnel repair manual
click this link below to see repair video for self propelled mechanism
http://www.youtube.com/watch?v=K722IsUxjYM&feature=related
Sep 03, 2012 | Hoover Vacuums
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Vacuums Logo
323 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
