How do I input sound on my Lenono N580 It has a combo audio port and of course the built in camera microphone.
Search for "windows recorder" in the start menu
Testimonial: "Wiondows 8 doesn't have a start menu, but I found the Windows recorder .... and it is moderately useful to record a conversation. But I was looking to import higher quality sound from my amplifier so as to make a CD out of an old cassette tape ... I have used the output jack on the amplifier to the "input" jack (mic) on a computer before. This machine has a built in mic and a combined audio jack (headphone)."
SOURCE: how to fix and install the built in microphone of my acer laptop aspire 4720z
go to contol panal select. run the hardware wizard, the old drivers are still in the sys32. Or you can go to the device manager and uninstall it reboot and it will find it again.
rank me if this helps
SOURCE: Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
SOURCE: No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
