Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Cannot retrieve data from my 500G WD
I have two questions:
1. My WD makes strange clicking noise and about 10 seconds later, the noise would stop and nothing would show up on my desktop (MAC) or in Windows Explorer. Who should I turn to to try to fix it?
2. If all I want to do is to have it reformatted, (I saved the data on a second hard drive, just in case something like this would happen) and do not wish to retrieve the data, how much would it cost to get it done?
  • hgrietkerk Nov 02, 2007
    My WD My Book Premium (320 GB) had the same clicking problem. It now refuses to start up. The harddisk starts turning and then after some hard clicks stops again. This happens each time I try to connect it.
    I am afraid this is a hardware failure... still would like to retreive the data that it on the disk. Can this be repaired?
  • Anonymous Mar 24, 2014
    Am in Adelaide.
    Brigadier General:
  • 6,966 Answers
For your 2 queries:
1. The clicking sound is indicative of a hardware failure or the start of one. Considering having it fixed would simply be buying a bit of time and prolonging the inevitable.  The drive even when repaired tends to be suspect and would defeat its very purpose;
2. You can perform the reformat yourself. If the WD would show as a removable drive in your Windows Explorer, right clicking on the assigned drive letter would give you the option to Format it.
Alternately, it might be to your advantage to simply replace the WD. In some instances, it is also possible to just replace the actual HD inside the enclosure.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Oct 28, 2007
SOURCE:
Dropped WD MyBook 2tb starts and stops working.
it would depend on how much vakuable data you have on your western digital and how much you $paid for and how much $ to retrieve the data
out of 10 9extremely
Oct 09, 2012 | Western Digital My Book Essential Edition...
How to recover my files from HD? I have Western Digital External hard Drive 500 GB.It was nearly full, such there was only 50 gb free space. Day by day it worked slow and one day It stopped working, not...
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more how to get the job done from: http://www.western-digital-data-recovery.com/
Dec 27, 2010 | Western Digital Passport WDXML800UE...
Clicking noise
The clicking comes fro damage done to the read/write head hitting either the swing stop or the heads are out of alignment and clicking the edge pf the platters. The drive is mechanically damaged and cannot be serviced with extensive cost. If you need the data, you will have to get the drive to a data retrieval company.
May 13, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
The machine made a slight squeek noise each time it slowed down and then started up again (durring the wash cycle) We also noticed a strange odor. It was almost a asbestos burning type of smell. Then later...
It probably mean the spin brake has failed. If everything else is functioning OK and it is not making anymore strange noises it will be OK however when you open the lid(during spin) if it takes more than 10 seconds to stop then the brake should be replaced. If you need anything else please let me know.
Mar 19, 2010 | Maytag Washing Machines
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Crashed hard drive
Seagate File Recovery for Windows is one of the best programs I've used. I had an external drive that was totally invisible to Windows until I popped it with this stuff and was able to retrieve everything on the drive within minutes. The stuff costs $129 but is well worth it. You should download the free trial just to see if it will access your data after which you can decide if it's worth the purchase price to recover everything...
May 06, 2009 | Computers & Internet
External WD my book 1T want boot on Mac or PC & makes click noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 07, 2009 | Western Digital MyBook Studio 1 TB USB...
WD 500 GB external hard drive problem -- works for 10 minutes
Here is another trick to help retrieve your important data. Put the hard drive in a zip lock baggie that's air tight and stick the drive in the fridge overnight. Next day as quickly as possible hook the drive up and try to get more of your data off before the drive warms back up and quits. This works! Some even freeze the drive, but try just in the fridge first. Good luck on the data gathering. Once other trick is to look at the controller board model number and try and find the exact same drive controller on Ebay or even the exact same drive and swap out the controller board. Most likely the controller is your problem, but it could also be defective sectors and that's a big problem. good luck.
Dennis
Apr 14, 2017 | Western Digital 500GB My Book World...
WD 500g hard drive computer cant read it
i suspect ,if there was no bad sounds on the drive when it was wrking ,that it must be the circut board on back of drive . i ,m in the same boat myself & i,m trying to track down same type of c/board.i do not think this is mechanical bit, electrictal
soretoe
Jul 17, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
246 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
