Question about Dell OptiPlex GX110 PC Desktop
Want to install more ram
How do i remove the side panel to install more ram and which side should i remove. thanks, john
    Brigadier General:
  • 6,966 Answers
There are two versions of this model: 1. Systems with slotted processor, & 2. Systems with socketed processor. Pls verify your model and choose/download the appropriate Service Manual which would contain detailed instructions as to side panel removal.
Good luck and kind regards.
Posted on Oct 28, 2007
  • Louie  Role
    Louie Role Nov 26, 2007
    Hi again,
    Appreciate the rating and glad to be of assistance.
    Cheers.
  • 37 Answers
Plz contact dell technical support toll free number :1-800-915-3355
Before You Begin To make working inside your computer easier, make sure you have adequate lighting and a clean work space. If you temporarily disconnect cables or remove expansion cards, note the position of the connectors and slots so that you can reassemble the system correctly.
You will use the information in this section every time you install a hardware option inside your computer. Read this section carefully, because the information is not repeated in detail elsewhere in this guide.
Safety First-For You and Your Computer Working inside your computer is safe - if you observe the following precautions.
want to install more ram - warning.gif WARNING: WARNING FOR YOUR PERSONAL SAFETY AND PROTECTION OF YOUR EQUIPMENT Before starting to work on your computer, perform the following steps in the sequence indicated:
  1. Turn off your computer and all peripherals.
  2. Disconnect your computer and peripherals from their electrical outlets. Also, disconnect any telephone or telecommunication lines from the computer. Doing so reduces the potential for personal injury or shock.
  3. If you are disconnecting a peripheral from the computer or are removing a component from the system board, wait 5 seconds after turning off the computer before disconnecting the peripheral or removing the component to avoid possible damage to the system board.
  4. Touch an unpainted metal surface on the computer chassis, such as the power supply, before touching anything inside your computer. While you work, periodically touch an unpainted metal surface on the computer chassis to dissipate any static electricity that might harm internal components. Also avoid touching components or contacts on a card and avoid touching pins on a chip.
In addition, Dell recommends that you periodically review the safety instructions at the front of this guide.
Unpacking Your Hardware Option When you remove an option from its shipping carton, you may find it wrapped in antistatic packing material designed to protect it from electrostatic damage. Do not remove the packing material until you are ready to install the option.
caution.gif CAUTION: Turn off the computer and unplug it from the electrical outlet. See "Protecting Against Electrostatic Discharge" in the safety instructions at the front of this guide.
Removing the Computer Cover To remove the computer cover, follow these steps:
  1. Turn off your computer and peripherals, and observe the Warning for Your Personal Safety and Protection of Your Equipment described earlier in this chapter. Also observe the safety instructions at the front of this guide.
  2. If you have installed a padlock through the padlock ring on the cover and the back panel (see Figure 5-1), remove the padlock. Figure 5-1. Padlock Installed
  3. Remove the cover. Facing the left side cover, press the release button (located at the bottom-left corner of the front bezel) and lift the bottom of the cover, allowing it to pivot up toward you (see Figure 5-2).
    Disengage the tabs that secure the cover to the top of the chassis, and lift the cover away.
Replacing the Computer Cover To replace the computer cover, follow these steps:
  1. Check all cable connections, especially those that might have come loose during your work. Fold cables out of the way so that they do not catch on the computer cover. Make sure cables are not routed over the drive cage-they will prevent the cover from closing properly.
  2. Check to see that no tools or extra parts (including screws) are left inside the computer's chassis.
  3. Replace the cover. Facing the left side of the computer, hold the cover at a slight angle as shown in Figure 5-3, and then align the top of the cover with the top of the chassis. Insert the tabs on the cover into the recessed slots on the computer chassis so that the tabs catch the hooks inside the slots.
    Pivot the cover down toward the bottom of the chassis and into position. Make sure that the securing hooks at the bottom of the cover click into place.
    Figure 5-3. Rewant to install more ram - fig5-3.gife Computer Cover
  4. If you are using a padlock to secure your system, reinstall the padlock.
  5. Clear the chassis intrusion alert message. Enter the System Setup program and reset Chassis Intrusion to Not Detected. See "Chassis Intrusion" for instructions.
SOURCE:
How do you install replacement memory to amilo pro series v2085 laptop
Most laptops have an access panel on the bottom of the laptop. Remove the screw on the panel and lift off the panel. The RAM module/s ia held in place by clips on the edge of the RAM module. Push the clips to the side and the RAM module will pop up at an angle and then pull the RAM module off the connector.
When you install the new RAM module/s just reverse the process of removing the RAM module/s.
Feb 12, 2012 | Computers & Internet
I want to install memory and after taking off the two screws, the cover does not want to come off and I am concerned that I will break the tabs or something.
After removing the battery, get a suitable screwdriver (normally the philips head screwdriver) and unscrew the screws on the memory module(RAM) section.Push the cover back away from the side where the screws were. When you open the lid covering the section, you will see the original RAM installed inside. Remove the RAM by lightly pushing out the side panels. The RAM will pop up and in a slanted position (around 45 degree) and then proceed to pull the RAM out.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2010 | Acer Aspire 5742Z-4200 Notebook
How can ichange memory & how to open computer
Turn your computer off, and disconnect the power-cord.
Look at the "back" of the desktop.
There will be screws holding the two side-panels in place.
Select the panel that is *FARTHEST* away from the many connections (keyboard, mouse, USB), and remove those screws.
Remove the side-panel.
Look for the stick(s) of RAM.
Count the number of "slots" for RAM.
Make a note of which slot(s) are in-use, and which are empty.
If you have "empty" slots, you can add sticks of RAM. Otherwise, you'll have to remove the RAM, and buy a bigger/better replacement (compare to replacing a bald car-tire with one with full-treads).
Disconnect all the cables from the desktop unit,
and take the computer to a computer-store.
They will check (online) to see the maximum amount of RAM that your Sony will support, and compare it to the current amount of RAM.
They will sell you "compatible" RAM, and probably, if you ask nicely, will install the RAM for you (it only takes 15 seconds). The "smaller" a computer-store that you pick, the more-likely that you'll get "free" installation, if you buy the RAM from them.
Jun 15, 2010 | Sony VAIO PCV-V200G PC Desktop
Where is the heater core located on a 1997 dodge ram 1500 5.2 318
This is to give you an idea where it's at (behind the dash) and what you would have to do to remove and replace it:
Removal & Installation
  1. Disconnect the battery negative cable.
  2. Remove the instrument panel from the vehicle.
  3. If equipped with air conditioning, recover the refrigerant.
  4. Disconnect the liquid line refrigerant line fitting from the evaporator inlet tube.
  5. Ram: remove the accumulator.
  6. Dakota, Durango: disconnect the accumulator inlet tube.
  7. Drain the cooling system.
  8. Disconnect the heater hoses from the heater core tubes.
  9. Ram: remove the powertrain control module from the dash panel. Disconnecting wiring is not necessary.
  10. Remove the four nuts from the heater–A/C mounting studs on the engine compartment side of the dash panel.
  11. Remove the nut(s) that secure(s) the heater–A/C housing mounting brace to the stud(s) on the passenger compartment side of the dash board.
  12. Pull the housing rearward far enough for the mounting studs and evaporator condensate drain tube to clear the dash panel holes.
  13. Remove the housing from the vehicle.
  14. Lift the heater core out of the housing.
  15. Installation is the reverse of removal.
May 08, 2010 | 1997 Dodge Ram 1500 Club Cab
Remove Dimension 2400 cover to install memory
The cover is normaly one of the side pannel board, u need to look for a screw that would keep it in place(look for a screw that will be afixed on the sidepanel with the back panel, once you have removed the screw just pull the side panel with force using a small hump that u may find on the side/back panel corner.
It's little trickey and need some concentration, u may find the RAM slot on the Motherboard (The RAM slot will be aprox 3 to 4 inch in length, the RAM goes in only in one way...)
hope this helps
Feb 17, 2010 | Dell Dimension 3100 PC Desktop
How do i change my heater core?step by step guide?
PLEASE DON'T FORGET TO RATE!!!
Heater core removal/installation
Nov 01, 2009 | 2000 Dodge Durango
How to upgrade acer aspire m1100 ram
It is actually pretty simple, just remove either screws or fasteners holding the case on. On that model it may even just be the side panel, which would be 2 screws/fasteners. Here is a video that explains the process. http://videos.howstuffworks.com/howstuffworks/26-how-to-install-ram-to-a-desktop-computer-video.htm Thanks,
Lee
Jul 09, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Low memory
Hi, first thing you need to do is remove the side panel of the pc and have a look inside until u find the other sticks of memory, once u do you will get the type of memory like ddr 1, ddr 2 etc has to be the same kind, you will be able to buy it from www.ebuyer.com cost about £12 - £35 for a 1 gb, depending kind of memory etc.
you will find step by step instructions here,
http://www.onlinepcstudy.com/documents/install_memory.html
thanks
John
Jun 03, 2009 | E-Machines eMachines T3830 PC Desktop
No power to pass side power window on 2002 dodge ram pickup remove motor try on diver side work fine
it's most likely the switch or the wiring. I would go with the switch first. I had the same problem once on a 1992 accura legend.
May 31, 2009 | MTX Dodge Ram Quad Cab 2002-2003...
Removal of cd/dvd tray from acer aspire 5051
hi
turn your laptop back there you can notice a closers like ram, hdd and cpu
remove the ram closer there you can see end of the cd drive, Before that screws which is indicate with the cd symbol,(see near the drive tray carefully)
then gently push the cd drive catefully from the back side , under the ram drive
Mar 17, 2008 | Compaq Presario 700 470024-192 Notebook
Dell OptiPlex GX110 PC Desktop Logo
336 people viewed this question
Clive
Clive
Alun Cox
