Question about Alfa CM-75 Coffee Maker
Part for coffee maker
I need a facet/nazel for my coffe maker, were can I get one and how much?
I just bought this coffee maker. I love it but the most I can program it to keep my coffee hot is 4 hours. I want it hot all day. What can I do? When it goes off, I can't even turn it back on again, even...
It is supposed to hold the coffe hot for 59 minutes , no more . After that it shuts off , fire hazard . Then you are supposed to wash it and make new coffe . Coffe after one hour tastes burnt , no good . Always make fresh new coffe .
Oct 28, 2013 | Cuisinart DCC-1200 Coffee Maker
My keurig coffe maker says it id "brewing" but
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 09, 2011 | Keurig B100 Coffee Maker
I can program or not and just brew. The coffee maker will change the clock time, how many hours the pot stays on (2-4) and just shut off automatically for no reason. Any help would be appreciated. ...
the coffe make is on a sencer timer built in coffe make for securty reasons its shots off after so many min. they built them that way so just in case someone forgets to turn off coffe maker and no ones home and burnes the place down.
Feb 24, 2011 | Cuisinart DCC-1200 Coffee Maker
Is it safe to use CLR to clean the Tassimo? The directions say not to use on coffe makers that hold water continuously.
White vinegar is usually recommended for coffee makers.. I would go with that..
"The directions say not to use on coffe makers.........."
Dec 11, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
My coffee machine is flashing
That means that you need to clean it...
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Apr 26, 2010 | Keurig B50 Coffee Maker
I have a cooks coffe maker (from JcPenny) my coffe
Wal-Mart,  BI-mart, Target, K-mart those kinda stores usally have them. or you can find the cook web site and try that.
Apr 20, 2009 | Cook's Essentials Cooks Essentials Arome...
I just received my cuisinart coffe maker DCC1200 and I wanted to brew a pot of coffe but I am unable to open the glass carafe to obtain my coffe filters. Is there a specific way to open this? Your...
Hmm. Better late than never. Just got home with ours. Same problem. Called Cuisinart 800 number. Catch is on top of handle. There is a slight lip on each side there. Pop it up with pressure on both sides simultaneously. To replace, line up lid carefully with top of carafe and press firmly until it pops back on.
Jun 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Alfa CM-75 Coffee Maker Logo
Top Alfa Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you an Alfa Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
