Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
Espresso side I was given a Bistro machine with no instruction manual. Making coffee is fine but how do I make espresso? Where do I put the water?
Re: espresso side
Hi. Was searching around and you can actually go to the krups website( and download the appropriate manual for your coffemaker. Its best to know the model number as well as the model name. On the Bistro, the coffee maker side should be on the left and the expresso side on the right. on top of the coffee maker on the right side is a screw on top(black in color depending on year of model). Simply unscrew and fill with water to recommended lvl. I would download the instructions first and become familiar with the process as it heats up the water to extremely high pressure and heat. Good luck..J
Posted on Jan 04, 2008
0 characters
3 Points
Water does not heat
PDF]Instructions for use (PDF) - Bodum
BodumCongratulations! You are the proud owner of a BISTRO pour over coffee machine fromBODUM®. Read through these instructions carefully before you use the
Aug 30, 2015 | Bodum Bistro Coffee Makers & Espresso...
Manual instructions bosch tassimo coffee maker
hi, this morning I was making a capuccino, and the first part was fine, the expresso was fine, I waited for the light to change colors, open the lid, put disc with the cream in the machine and the green light won't come on, only the yellow on the left hand side and is not working<br /><br />
Aug 22, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Krups 867 Bistro Coffeemaker
Jan 28, 2010 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Where do i put the milk?
Please follow this LINK
Than go to instruction manuals.
Food preparation. Coffee and espresso makers. And click on BCO70
that will give you your instruction manual
Jun 05, 2008 | DeLonghi Caffe Nabucco BCO70...
Where does the milk go
Follow this link.
Goto instruction manuals, espresso /coffee combo
I have the krups espresso and caffe machine and i have no idea how to MAKE espresso (it's NOT the one below)...
turn on your krups espreeso to warmup the water, put one spoon of coffee in the handle, lock the handle and turn on the pressure button, and the coffee leaks in your cup, that's all
Apr 27, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Icky stuff
I would suggest to disassemble the machine and clean individual parts, chunky orange is rust, which is not normal in the coffee machine tubing.
Jan 30, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
137 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Sergio M Perez
Ernest R
Ernest R
Mike Cairns
Mike Cairns
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
