Question about Kenmore Elite 45986 Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
After 13 months of using, no problems - always used He detergent. At beginning of another normal load, got the F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer Care") and ran a cleaning cycle. After 6-9 times of trying another clean cycle, always got error F35 with SuD, although water was flowing through the machine normally!
  • 2 more comments
  • Anonymous Mar 14, 2014
    Keeps giving sud error
  • Anonymous Mar 19, 2014
    Error code F 35 and SUD
    F 35 error code and SUD
  • Anonymous Mar 24, 2014
    on any cycle washer gives code F35 and stops working have cleaned with bleach on cleaning cycle
  • 44 Answers
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Posted on Jun 10, 2009
    New Friend:
When my kenmore elite 4he was displaying SUd and f35 I ran the clean washer cycle with no clothes or any soap added to the soap dish. So far I don't have a problem with the washer yet. You should always check underneath the rubber around the front. Make sure there are no objects underneath the grey rubber.
Posted on Feb 22, 2011
  • MsJae
    MsJae Nov 16, 2013
    Thank-you! This method worked for me. I looked under the rubber molding and found a small toothed comb lodged in there. Started up the washer with a load of clothes on Normal and it worked without fail! Thanks again for sharing and saving me $$$$!
    New Friend:
Replaced the sensor and still not working. after about 40 seconds the Sud light starts blinking! Ideas??
Posted on May 30, 2013
  • 1 more comment
  • Tom Manning Oct 02, 2013
    Check the drain tray at the bottom of the washer by removing bottom front panel held in place by 3 screws
    There is a you tube video explaining that the blocked drain at the bottom front may be the issue if replacing the pressure switch doesn't work
  • Tommi Oct 17, 2015
    Replaced switch. Drain not clogged. Blew thru switch hose to insure no obstructions. Still SUD or F35. Removed front top and back to check for loose connectors or kinked hoses
    Still nothing.Really fed up. ANY OTHER IDEAS????
    Sergeant:
  • 220 Answers
Found another post, on here, that says to check the rubber seal, on the housing that the rubber hose attaches to. The rubber hose from the pressure switch go onto the white plastic housing at the bottom of the tube. They say that this small white plastic housing comes loose from the main plastic tub housing. The gasket is a rubber seal and needs to be a good seal.
Posted on Sep 27, 2014
SOURCE:
He5tsteam kenmore elite smartwash quietpak9 keeps flashing F35
Analog sensor failure. Replace that puppy using this VIDEO GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2012 | Kenmore HE5t Steam 4.0 cu. ft. Front-Load...
Code SUD and F35
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 5t steam f35 and sud problem
- Link 1
- Link 2
Kenmore Elite He5t front load washer. SUD shows for a few minutes then up comes error code F35. Then all controls are locked out. Unplugging machine and allowing reboot fixes problem for a wash load or...
Remove the lower front panel and unscrew the cap from the pump and drain the water and clean the filter and then run it a few times with no soap at all an dit should clear the system ,,, have some towels handy when you remove the filter.
If the problem remains unsolved, then you need to replace the pressure switch.
Explanation
Sud" SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
All possible reasons
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
As i mentioned, on most occasions, this is due to faulty pressure switch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 01, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
What is error F35 & Sud?
using either the wrong detergent , not  HE specific, or way too much..
Jul 19, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
9,489 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
