Question about Vacuums
Hoover power head
I have a hoover vaccum and i need a new power head model no pb4 other nos cs4901n and n127. how much to buy a new one or can you replace the broken plastic parts.
  • Lauren Junge
    Lauren Junge May 11, 2010
    What is the model number of the vacuum, you can replace most of the parts, but need the number to look it up.
5 Suggested Answers
  • 7 Answers
SOURCE: Hoover Model S3755 Parts List Needed
Go to and look up a local Hoover store. Give the a call and ask the to mail of fax you a schematic. They should be pretty helpful.
Posted on Jan 07, 2008
  • 97 Answers
SOURCE: We have had three belts break on your hoover
sometimes when you buy belts from the walmart or target, they are not at the correct specification and they brake as soon as you turn on the machine. i would suggest that you buy these belts from the company.
Posted on Jul 19, 2009
  • 438 Answers
SOURCE: I have a Hoover Model #U6430-900, Self-propelled
Hi There,
Here's a step by step guide that will explain in detail how to remove the top cover on your Hoover. The repair was written for a different problem then one you're experiencing, but you can follow along step by step to see how you can remove the top cover.
If you haven't already purchased the actuator arm, here's a link for you to the part on Amazon
Hoover Windtunnel Self-Propelled Windtunnel Actuator Arm
Here's the repair guide:
Step 1. Make sure that the vacuum is unplugged. Turn the machine upside down so that the brushes are facing upwards. I find the easiest way to do this is to put the brushes on top of a counter top or work bench with the handle of the vacuum resting on the floor. Remove the four screws that hold the bottom plate in place. Remove the bottom plate, both belts and then the roller brush from the machine:
Step 2. There are 3 screws that hold the top brush cover in place that need to be removed. On the right side the screw is down below the transmission to the right. There's also a screw in the agitator tray, in the middle that needs to be removed. NOTE: This small screw in the agitator tray is only present on some models, you's may or may not have this little screw, but all models will have all other screws circled. I have circled both screws that need to be removed:
The screws on the left side that need to be removed are also circled. One screw holds the upper brush cover on, and the other two screws secure the hose in place. Remove all three screws as well as the transparent hose cover:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The right side clip is near the pulley that the flat belt2_bing.gif rides on, and the left side clip is next to the internal hose.
Step 4. Once both of these clips have been pushed so the unhook from the lower agitator housing, remove the top cover.
Once you have removed the top cover, here's a link to a guide that will show you how to replace the actuator arm itself:
I hope that this information helped you fix your vacuum cleaner. If you have any follow up questions, or need clarification on something, please feel free to use the comment box here on the Fixya repair page, and I'll be happy to answer any of your questions.
If this was helpful, please be so kind and rate the repair, or leave feedback. This is greatly appreciated by the Fixya community if an answer was helpful.
Thanks again,
Chris Jones
Posted on Jun 15, 2010
  • 4 Answers
SOURCE: hoover u5180-900 vaccum ..has all the parts and parts sheets with pictures that you would need..also much cheaper than any other site i have been to..
Posted on Jul 09, 2010
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Hello, I have a Hoover quadraflex Powermatic central vacuum system Model # s8099-031 that requires a new replacement 35 ft hose...I have contacted Hoover and they do not know where to buy a replacement...
Tammy, no info re your location, so I''l try this.
Your Hoover hose is shot because it was made of rubber.There are new swivel handled, tangle proof lighter hoses made of vinyl which will last much longer and can be adapted to the old Hoover head by changing the upper steel tube.
Find a Hoover service center, outlet in the yellow pages and ask for the "NEW "style, gray``Plastiflex`` brand hose and upper adapter tube sold with new Hoovers at Costco and you will be all set. Then, when the head eventually dies, you can upgrade to a far better one , while still having the Hoover cannister, the hose and tools do not need to match the original tank.
Sep 17, 2009 | Vacuums
Part terminology and replacement help
call tti floorcare 1800-321-1134. have your model number and the plant number ready you will need it
Apr 18, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
A noise coming from the motor when I`m ready to vaccum
if it were m i would take it back and insit on a new one.something new shouldn't have to be fixed thatd why we buy it new
Dec 31, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hello . The beater bar is not spinning on my Hoover bagless upright rewind. Can I fix this?
very simple to repair its a broken belt read owners manual or somtimes they print instructions on the head of vaccum belts are sold at walmart you must know make and model or get number of old belt. before buying one check the back where the attachments are some cleaners have spare belts
Jul 20, 2008 | Hoover Vacuums
Jan 07, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Hoover Wind Tunnel Problem
motor burnout. replace the motor or get a new vacuum
Dec 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Vacuums Logo
116 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
