Question about LG Chocolate Clamshell VX8600 Cellular Phone
Won't Turn On/Charge
My LG VX8600 was working perfectly fine and then suddenly today it turned off and now when I press the power button, the verizon wireless screen turns on for as long as I press the button and then it dies again when I release. I tried taking out the battery and leaving it out and also charging the phone and the same thing happens. Any ideas on what the problem is and what I can do about it?
  • 8 more comments
  • gabe101 Nov 30, 2007
    my phone has the exact same problem, I do not know what to do, please help!!!!
  • Anonymous Dec 06, 2007
    mine is doing this too.
  • Anonymous Dec 08, 2007
    So is mine!
  • KickNine Feb 10, 2008
    Pretty much same thing, only phone simply wont charge, battery is completely dead now. Tried the sand paper thing and it wont work. Looks like there is corrosion in the charging port. HELP!
  • kacey21x21 Jul 09, 2008
    Mine won't charge anymore, I used to have to wiggle it until it would start charging, and then leave it there untouched until it got fully charged.  Last night it tried doing that, and it didn't work.  I NEED my phone and am very upset.
  • mallycat310 Aug 23, 2008
    my phone is tow weeks old, its only dropped once and i always keep it in the case. suddenly it acts like its not charged although its been plugged in for a day. it will only show the LG start up screen as long as i hold the power button then it turns off. and when its charging it wont ever charge, as soon as i unplug it, it will show empty and power down. ive tried other batteries and other people have tried mine. mine works in there's but nothing works in mine.
  • mummaL2 Sep 19, 2008
    My white chocolate through Telus has a similar problem... it was working fine. had my phone ALMOST a year and now the past week or so it will suddenly shut itself off out of no where or if i open it to fast or close it to fast. and once it shuts off i try to turn it on adn all it does is show theLG logo then the screen says at the bottom "battery power off" now it wont turn on at all. thats all i get. i have taken the battery out and left it out for a few hours and i have tried charging it although before it shut itself down it had full battery charge. no idea what to do now!
  • Anonymous Dec 15, 2008
    i have had the same problem, meaning my phone will just shut off. i went into verizon the first time and just had it replaced. unfortunately it happened again and my warranty is up. i figured out it was the copper peices that connect the battery to the phone itself. there are supposed to be four copper colored metal pieces that show, but one was pushed in to far for some reason. i dont know if i did it or if it just got jiggled around too much and happened that way but that was the problem. now my problem is that i did that so much i broke it off by accident. not good to play with it too much if that is your poblem and you do try to fix it.
  • puppygirl26 Mar 20, 2009
    I will try charging it but nothing happens. Then when i turn it on it starts turning on and then just shuts off. A couple of days ago when it was working in order to charge it i would have to wiggle the charger around till it beebed and then sit stuff on top of the charger to get it working
  • Anonymous May 18, 2009
    thats the same as mine, but atleast i know im not the only one.
    i dont think i have turned by phone off more than 10 times after almost two years, so i think that may be the problem.
    but this isnt the first time this happened, this happend almost a year ago and i had to get it fixed. Then when i got it fixed bell send me instructions on to how to properly charge my phone...
  • 3 Answers
When that happened to me it could have been caused by two possible problems:
1) water damage. If you know it's not water damage, it still could be because if you had your phone in the bathroom while having a shower, steam can seep in and if it's one thing I noticed about chocolate flips they get water damage really easily.
------>>> If that is the case then you have to take your battery off and take a really fine ground sand paper and rub along the contacts (like the copper that is on the battery and the phone that touch when you put ur battery in) and that will rub off any kind of oxidization (rust) and possibly make your phone work. It happened to mine and I did that and it was successful
2) you could not be turning your phone off regularly enough. Technically, you are supposed to turn your phone off every night when you go to bed to give your battery time to re-vamp. Also, I was speaking with a rep from telus and they were saying that you should also turn your phone off during the day, just for a minute then turn it back on again and apparently it recharges the battery as well.
Hope this helps!! It only comes from personal experience so it all depends on the reason why it's doing that.
Posted on Dec 09, 2007
I have this same prob it just started today i hope that verizon will replace it i had the same problem wit the last one that i had and now this one!!!!!!!!!!!!!!
Posted on Aug 08, 2008
I just got this phone today and went to charge it and when I plugged the charger in it beeped crazy at me and wouldn't charge... eventually the battery died and I still can't figure out how to make the charger work.. according to my friend who has the same phone it was plugged in correctly
Posted on Jul 03, 2008
I've went through this problem with four different LG Chocolates. The manufacturer puts these phones togethers rather poorly. The main problem i had is the port in which you plug your charger into breaks. The only real solution is to replace the part if they even have any more, or replace the phone. When the port breaks it makes it impossible to transfer your contacts and other information to the replacement phone.
Posted on Feb 22, 2008
My LG Chocolate has just done the same thing, plug the charger in and nothing happens try to turn it on and nothing, i hope vodafone take it back lucky i have 3 weeks of warranty to go
Posted on Dec 18, 2007
2 Suggested Answers
yvonmagic
  • 82 Answers
SOURCE: Won't Turn On/Charge
hi , i know a friend have one like that, same probleme he have to bring back to make it fix by the compagny,, only help can give you Yvon chow !!!
Posted on Jan 02, 2009
How can I get my Verizon lg to turn on
Verizon Wireless Phone Guides - LG
www.verizonwireless.com/.../HowToControllerServlet?...
Verizon WirelessVerizon Wireless Phones. ... Note: Your model name appears on the screen immediately after turning on your device. *To view the PDF file, you may need to
LG G2 Support ' Verizon Wireless
www.verizonwireless.com/support/g2/
Verizon WirelessManage your device in My Verizon ...... Enable/Disable Voice & Video - Advanced Calling 1.0 - LG G2 ... LG G2 Simulator: Turning Airplane Mode On and Off.
Enable/Disable Data - LG G2 ' Verizon Wireless
Dec 10, 2015 | LG Cell Phones
Lg g2 will not turn on
  1. Take your phone and turn it off - just press power button and select "power off".
  2. Wait while your device is shutting down.
  3. Then, press volume down button and power button together until the LG logo appears on the screen.
  4. When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.
  5. Once you do that, on your LG G2 the factory reset menu will be displayed.
  6. Press power button in order to agree and wait while the hard reset is being completed.
Jun 09, 2014 | LG G2 White for Verizon Wireless CePhone
I've had my LG Dare for about a year now, and just recently it has been very irritating trying to turn it on. The phone flat out will not turn on. I connect it to the charger and it doesn't say the normal...
I'm having the same problem! It started today again. I've have this problem on and off for a while. Then all of a sudden the phone works fine. Try removing the battery...let it sit for a bit, then try to turn it on. Its worked for me before but is not working today. Sorry, I know how frustrating it is!
May 03, 2010 | LG Dare VX9700 Cell Phone
Jan 02, 2009 | LG CHOCOLATE VX8500 Cellular Phone
VX9400 problem
I had the same issue, but knowing some things about computers, I took the battery out for about 3 minutes or so to let the phone lose any charge it had. Then I put the battery back in, held the send button in for a minute then pushed the power button and it turned back on fine.
Oct 04, 2008 | LG VX9400 Cellular Phone
Tablet will not turn on
I had the exact same problem. Finally, I pressed all the three buttons, power, left click and right click buttons and held it for several seconds. After that, the tablet turned on.
May 21, 2008 | Wacom Graphire A5 (CTE630BT) Graphic...
Display on LG VX8600 screwy
well most probably your lcd screen is fualty you can fix this yourself with a t6 torx screwdriver and a new lcd screwdriver that will cost you around 15 pound on ebay , hope i helped
Oct 17, 2007 | LG Chocolate Clamshell VX8600 Cellular...
Turns on and turns off
I have the same phone and it is doing the same thing, i called about it and i was told to bring it back to the dealer as it needs to have it's software up dated, he called it a "flash" I haven't had it done yet but will report back when and if it works for me.....
Oct 14, 2007 | LG Chocolate Clamshell VX8600 Cellular...
LG Chocolate Clamshell VX8600 Cellular Phone Logo
4,084 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
