Taking your vehicle to a qualified repair shop instead of mess with thing's you have no clue about ,is what you should have done . Replacing BCM'S - needs to be programmed .
If the body control module (BCM) is replaced, the following procedures must be performed in the following order:
BCM reprogramming--Refer to Body Control Module (BCM) Programming/RPO Configuration in Computer/Integrating Systems.
Theft learn--Refer to Programming Theft Deterrent System Components in Theft Deterrent. A new BCM will learn the Passlock™ information automatically but the powertrain control module (PCM) must still learn the theft information from the BCM.
Plus the bcm has nothing to do with the power window's DDM -the driver door module controls the window .
Programmable Automatic Door Locks
The automatic door lock feature can be programmed to control the door lock system. The automatic door lock feature is factory programmed to have all doors lock and unlock. For detailed instructions on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
When the automatic door lock feature is programmed to control the door lock system, the driver door module (DDM), passenger door module (PDM) and body control module (BCM) will lock the vehicle doors if the following inputs are true:
• Ignition 1 input is active.
• All door jamb switch inputs are inactive.
• Cargo door or liftgate/liftglass ajar inputs are inactive.
• Transmission is shifted out of park.
This automatic door lock function will only occur once per ignition cycle unless, a door jamb switch input changes state to active and back to inactive. Then the DDM, PDM and BCM will lock all doors again.
Once the automatic door lock feature has locked the doors, the BCM will then unlock all the doors when the transmission is shifted into park.
Before replace these componets hooking up a factory scan tool an checking data input's an DTC'S - diagnostic trouble codes .
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Operate the driver power window in the UP and DOWN directions.
Does the driver power window operate properly?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Install a scan tool.
Monitor the driver window status data parameter in the Driver Door Inputs List.
Does the driver window status data parameter display an active state?
YES - Go to Step 11
NO - Go to Step 4
Monitor the driver window status data parameter in the Driver Door Module Inputs List.
Activate the driver power window switch in the up and down positions.
Does the driver window status data parameter change accordingly?
YES - Go to Step 5
NO - Go to Step 11
5
Connect a test lamp to a good ground.
Backprobe the battery positive voltage circuit at connector C1 cavity 2.
Does the test lamp illuminate?
YES - Go to Step 6
NO - Go to Step 13
6
Disconnect the driver power window motor.
Probe the power window motor up control circuit at the power window motor harness connector.
Activate the power window switch to the UP position.
Does the test illuminate?
YES - Go to Step 7
NO - Go to Step 9
No where in the fatory service info does it say replace the BCM for a none working driver's door window ,DDM yes ,but that's after testing .
SOURCE: 2001 volvo V70 T5 Problems
Had this same problem with a 2001 v70. Dealer needed to download new software to the computer. Took about 20 minutes and solved the problem. (The problem happened at 10 degrees below zero and I went in to see if they could tell me where the fuses for those circuits were located.)
Unfortunately the sofware re-load was not cheap.
SOURCE: 02 saturn l200 starts then dies immediately
try your spare key it sounds like the transponder in the key is going bad
SOURCE: in my 1997 Chevy Lumina 3.1L the CHECK ENGINE SOON light is on
If it was a stock rebuild the original PCM settings should be fine check all the fuses and wiring possibly something was damaged or left loose this stuff happens to the best of us.next the SES light needs to be reset with a scan tool make sure to record all codes stored in the computer as this will aid in diagnosing any problems. the car must be ran thru a drive cycle usually normal driving conditions of say a mix of city and highway driving until the PCM relearns all parameters like o2 sensors emissions sensors ect... this can also be checked with the scan tool in the readiness moniters these monitors will be reset every time the SES light is reset. when pumping the gas pedal 3 time you are just resetting the maintenance light.
SOURCE: ABS, Service Engine Light
This is normal for your anti-lock brakes to quit when the abs light is on.What you will need to do is retrieve the codes and then you can find out what part of the abs system is giving you the problem.This will also cause the check engine light to come on.You can post back and I can help you with the code or codes that are in the brake control module.Hope this helps.
SOURCE: Engine light and ABS traction control light remain
The ABS sensor is a speed sensor also for Traction Control. This is why both lights are on , One of your front ABS sensors are bad or disconnected, or has a pinched wire.
Command the driver door and passenger door lock actuators to LOCK and UNLOCK with the scan tool, the doors should LOCK and UNLOCK when changing between commanded states.
If a door lock actuator does not perform the LOCK and UNLOCK functions, refer to Door Lock Malfunction
DTC B3130 00: All Door Unlock Circuit
DTC B3135 00: All Door Lock Circuit
