You can check the hard drive using Norton Utilities software. There is a trial version (free). Most of the modern laptop hard drives do not make a loud noise (it make a noise when it writes something). If your laptop uses an indexing software, then yes, the hard drive will make a noise all the time.
Hi - Generally speaking, it is normal for Frigidaire refrigerators to making a vibrating, snapping, dripping noises however not a chugging noise. From what you have described it sounds like it could POSSIBLY be the drain sucking in air or it could be refrigeration through the evaporator. A constant noise could indicate a serious problem with one or more components. This is a repair that should be left to a refrigerator service expert.
