Question about Belkin IEEE 1394 Firewire Cable (f3n402-14-ice)
Unable to plug into PC
I have one side of the cable hooked up to the camera but I don't know where to put the other side of the cable into the computer.. Is it in the back or in the USB Port?
  • Anonymous Mar 04, 2009
    Me too I think we need firewire ports or something like that
  • 328 Answers
A firefire cable gets plugged into your video card at the back (smae area your monitor is plugged in) providing you have a firewire capable video card.
Posted on Oct 28, 2007
Don't know how to recharge
Just use the combined USB/audio cable. Plug the standard USB side in your computer, or even in the back of some modern TVs, and then plug the other side with the smaller USB plug into the speaker.
Sep 29, 2012 | xMini X-Mini II Portable Capsule Speaker -...
My daughter was given a Disney Digital imaging (smile) camera. I hooked it up to computer, but nothing? The amera says it has 4 pictures on it
Your computer must recognize your camera automatically,.
Go to control panel -- device manager and look if they are a device iht a yellow mark .
If have a yellow mark, select and rigt clik "uninstall"
Restart your PC
If don``t work
Try connect in another USB Port
Try connect in another computer
If don`t work, maybe the USB cable is failure
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Disney Pix Click Digital Camera
I connect the IEEE cable (4 pin to 4 pin) to the camera and the computer and turn the camera to "play". The camera is not recognized by the computer.
Check the cable first. It's easy - put another one. If it works - change the cable. If Not - check the PC input by connecting another similar camera. If it works with another camera, then Your IEEE camera port is broken and needs to be repaired. And the order of connection must be: 1. Power off camera. 2. Put IEEE cable on it. 3. Plug another connector of cable on computer. 4. Power on the camera. DON´T TRY TO CONNECT A CAMERA IN A PLAY MODE, it probably can destroy Your camera IEEE port. Sincerely.
Sep 11, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Unable to transfer photos from memeory card with usb cord
uninstall fuji software from laptop. plug in data cable, pc will ask u for drivers then load it. if not then pause antivirus for while then use data cable
Jun 18, 2009 | Fuji FinePix Z10fd Digital Camera
Xbox live vision camera, lost most of color!!
the camera might have a problem with the optical sensor. to make sure, you ned to take apart the camera and see if there are any loose cables or wires leading up to the optical sensor. if not, then you may need to invest in another camera.
Mar 01, 2009 | Microsoft Live Vision Camera for Xbox 360
Unable to export video from camcorder to PC
Get a 4-pin Firewire cable. Plugs in just below power plug slot. What plug you need on the other end depends on your computer. You can get Firewires in 4 to 4 pin; 4 to 6 pin, and 4 pin to USB. My laptop is configured to take a 4 or 6 pin Firewire but my desktop only has USB. I transfered using 4 to 4 pin and it worked great. No drivers, no discs least with Vista. As soon as I plugged in the camera, I was asked to whether I wanted to transfer from biginning of tape or at currenty location. I chose from the beginning and the camera automatically rewound and strated to transfer to the PC. I don't know if it would work same way with 4-wire Firewire to USB but assume it would. Cables around $35 but I purchased at Circuit City for the going out of business discount. I also bought some SD cards so I can take snapshots and transfer them too for print.
Get a firewire and you should be fine.
Jan 13, 2009 | JVC GR-D270 Mini DV Digital Camcorder
Brothers printer
First install the driver disk that came with your printer (you should be able to just put the disk in the cd/dvd drive and the program will start to install automatically. Make sure the printer cable is unplugged. Then just follow the prompts for the program. The program will tell you when to plug in the cable. If you are unsure of where to plug in the cable, lift the scanner bed (not the little door where you put the document to be scanned) which is located on the right side underneath the document plate. On the right side closest to you, you will see a connection point shaped like the small end of your usb cable that came with the printer. Plug it in then route the cable in the slot that runs front to back and out from under the scanner top. Plug the flat end into your computer and you should be good to go. I hope this answers your question...
Dec 18, 2008 | Brother Multi-Function Center MFC-240C...
Camera hooked to computor?
you need a USB cable that usually comes with the camera, and once you plug it in, your computer should find the software to upload the pictures on to the harddrive. Similar to how you would use a firewire to transfer videos. You can buy a USB cable if it didn't come with your camera
Sep 05, 2008 | Video Cameras
Unable to download pictures from camera to pc
There are lots of different USB cables, not a real standardized piece. Try the USB that came with the camera or buy one that has your model listed. I have many and they all are specific to their models, some charge but dont sync, while others sync but dont charge, and some just dont do anything.
Feb 12, 2008 | Canon PowerShot SD950 IS Digital Camera
Unplug your camera cable from your computer, restart your computer , plug again your camera while pc was on, the screen will display press to download then ok.
Dec 28, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Belkin IEEE 1394 Firewire Cable (f3n402-14-ice) Logo
66 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
