Question about GE Spacemaker JVM1640SJ Microwave Oven
Spacmaker xl sensor
I've got the top screw off the broken handle, but can not gain access to the bottom one to unscrew the broken handle piece.
  • 3 more comments
  • Anonymous Nov 02, 2007
    Same problem.
  • thebigragu Dec 27, 2007
    Has run just great for 2 yrs. then started up and sounded like the plate was struggling to turn then popped breaker, reset breaker and now nothing. No lights-nothing.. The circuit is working after reset. Turning the plate manually seems like the plate motor is bad as it's really hard to turn. My guess would be that it's cheaper to buy another than to fix. GE Spacemaker XL 1430
  • rina99 Dec 30, 2007
    Does anyone have an answer to this question, we got the top screw off easy enough but the bottom screw is hidden inside the door panel. How does one gain access to it?
  • SusanAmy Jan 09, 2008
    My handle broke and I want to replace it. I have not found a new one, yet. I will look at the screw placement tonight.
  • malcolmdm1 Dec 09, 2008
    The botton half of the handle broke. Have not searched for a new handle or door yet.
I fixed it. You need a few thin tools. I used 2 putty knifes and old knife and a long screw driver. The inner cosmetic ring needs to be removed first. The putty knifes and knife can lever in to unlatch the molded in latches. Be cafeful not to break them. The edge along the hinge is most difficult and where I used a long thin screwdriver to release the catches. Remove the visible screws that retain the handle, there are two more screws which are revealed once the front panel is off. The front glass panel is then removed by releasing the catches around the inside perimeter of the window. Remove the glass and the handle will follow. Replace. Done.
Posted on Mar 20, 2008
  • 3 Answers
If anyone wants to replace the whole door contact me. I've got an couple of extra ones in great shape. The door comes off really easy. Michael_Wassmuth@agilent.com.
Mike
Posted on Nov 06, 2007
Same goes for me. I can get most of the trim off but not the area near the hinge. ! It will cost $100 for GE to come out, and I already own the new handle. Come on GE tell us the secret.
Posted on Nov 03, 2007
Microwave door handle
Hi have a nie day!
You may use a electric drill and the a screw extractor so the handle be released.
Mar 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
How do i remove the cover to change the light bulb inside?
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Nov 20, 2010 | Neff H7871 Convection/Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
334 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
