.... Robert Grove
johnallen496, when you say it stalls at low speeds and stops, do you mean when slowing down and coming to a stop? does it stall at low speeds while the car is moving with your foot on the pedal just a little like when driving through a parking lot?...
I used the wrong box above, oh well ....
The most common cause of stalling at low speeds, especially idling and decelerating to a stop is carbon buildup. The throttle plates get coated with carbon closing down the opening slightly, this affects the idle speed, causing the engine to stall at idle and coming to a stop.
also carbon builds up in the cylinders and absorbs fuel intended to be burnt, leaning out the mixture and causing rough/low idle and stalling - especially when the engine is cold. Dirty injectors can cause the same symptoms/results
As a maintenance routine It's good to have the throttle plates cleaned and perform a top engine de-carbon treatment, and fuel injection service in more severe cases
Sea Foam makes a spray that works great for minor de-carbon service, just spay it into the throttle plates while it is running, one to two cans will do, add a can of Sea Foam or Techron to the gas tank each time you fill up for the next few tank full's.
If you still have problems sek out a qualified professional
Robert Grove, WEGO2U Mobile Mechanics
Orange County Mobile Mechanic Orange County Mobile Mechanics 714 709 4594
SOURCE: My Neon keeps stalling
Try the simple stuff first and ask yourself these questions:
How old are the spark plugs? (I think this is 90% gaurenteed the problem)
Is the car getting enough air through the filter?
Is the filter dirty? (replace if so)
If not you might need your idle advanced a little.
SOURCE: stalling problem
throttle plate is most likely dirty from using cheep gas. the carbon build up will hold the throttle plate open to wide for it to idel right, another symptom is poor fuel econemy and all cars do it with enthonal running in the car now and also plugged fuel filter from the ethonal. thank congress.
SOURCE: '92 Dodge Caravan low speed stall.
Try cleaning the throttle body. Buy a can of throttle body cleaner, on newer cars you shouldn't use carb cleaner. But given the age of your van the protective coating on the throttle body has probably worn off anyway so if you already have a can of carb cleaner use it. Just buy a can of silicone spray to lubricate and prevent the TB from getting getting gummed up to quickly. Also check the EGR valve as it causes a lot of stalling problems on Caravans. Vacuum test the diaphragm and remove and clean the port and EGR plunger. You should replace the fuel filter if hasn't been replaced in a while. The transmission torque converter lock up solenoid might be sticking too. Just have the computer codes scanned as the EGR valve and lock up solenoid should turn on the check engine light.
SOURCE: The engine stalls when I turn the wheel at low speeds?? Help
power brake booster may be at fault so check the vac hose to it & the valve & its rubber grommet
Cheers rob
SOURCE: 1997 dodge stratus stalls when at low speed coming
fuel pump pressure is low i suspect but i could be wrong
Engine stalls, car stalls while
starting, vehicle stalls while starting, Engine stalls and dies, Car stalls and
stops,
http://alltypesofpartsreplacing.blogspot.com/2012/12/engine-stallscar-stalls-while.html
These will help.
Thanks.
Engine stalling and rough run
issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
one thing that a lot of people overlook is the kill switch solenoid situated on the carburator body have a look for a single wire running to the carb and just check that its working this solenoid often gets sticky and should be replaced so maybe this could be the problem
