Question about Belkin (F6C800-UNV-PL) UPS System
Belkin UPS F6C800 Problem
This UPS shuts down whenever there is a power surge from one of the connected components.
It is only supposed to shut down upon short circuit and none have occurred. Is this indicative of a different problem?
  • UPS Man Oct 28, 2007
    Thumu had some good points but it does not really addresss the problem.
    The UPS battery backup works and is plugged in under normal conditions.  When a surge comes, like the CRT monitor is turned on, the UPS completely shuts down.  It does NOT go into battery backup mode and no alarm comes on.  It just completely shuts down and cuts off all electricity like a short circuit.  Push the on buttom for 3 seconds or more and the UPS comes back on.
    I do have a laser printer plugged into another outlook on the same circuit as the UPS but even when the printer is off, the monitor coming on can shut the UPS down.
    This problem remains a mystery but I suspect that somehow the UPS has become hypersensitive to power surges and shuts down instead of protecting.
  • 3 Answers
I have a belkin f6c1100unv. I plug in the cord to the house outlet.The outlet has power. I push the on/off button. No green light. I check the reset button -ok. Check the fuses inside-ok. Check the batteries with volt meter-.51. Can you give me any other ideas? Bob
Posted on Mar 30, 2010
    Novelist:
  • 169 Answers
Just a general point. any ups is designed to deliver power inside its design parameters. any load outside its design parameters will cause it to shutdown or in the case of more expensive models it will go to bypass, some models will then recover and go back to inverter.
eg stable overload
peak overload
load outside its normal crest factor
short circuit
Posted on Apr 23, 2008
    Novelist:
  • 69 Answers
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Shutdown of UPS whenever there is a Power Surge. I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
I see that you are using
Generally, the issue happens if you are not using the UPS as per Manufacturer specifications or if it is overloaded frequently then UPS  shutdowns
To isolate the issue, I recommend you to check and go through below information.
If you see ON BATTERY a Yellow LED OR Flashing Yellow
LED with Audible Alarm (Beeping) then it means this condition for the On-Battery LED can indicate 1of 2 problems: They are:
1. The UPS is on battery backup and an intermittent audible alarm is on. The UPS will begin shutdown procedure.
2. Battery is low. The UPS will sta rt shut down. The buzzer sounds an audible alarm .
if you see a Solid Red on your UPS , then it means that UPS is either fault or overload.  It happens if there is a issue with UPS. The LED will be lit continuously and the unit will sound an audiable alarm for 10 seconds. Other cause could be with Battery is weak or Bad, the Battery needs to be replaced under this condition.
If you use a Flashing Red LED, then it means that battery is trying to give more power than it should. It happens then UPS is overloaded.
Let me tell you,,,,
Only data sensitive equipment such as a computer, monitor and external drive should be plugged into these outlets. Battery power is automatically
provided in case of a power outage. Power (AC or battery) is not supplied to these outlets when the UPS is switched off. (Do not plug surge protectors or power strips into the battery back up outlets).
 Most Important factor that effects the issue is that,
Caution: Never connect a laser printer or scanner to the backup outlets of UPS with other computer equipment. A laser printer or scanner draws significantly more power when in use than when idle. This may overload the UPS.
And caused the UPS to shutdown whenever there is Power Surge
To isolate the issue further, let me tell you the way where you can test the UPS if it is fine or not.
1. Charge the UPS for around 4 hours, and try below steps.
To Conduct a Self Test
Use the self-test to verify both the operation of the UPS and the condition of the battery. In normal utility power, push the On/Off/Test
button less than 2 seconds and the UPS performs a self-test function. During the self-test, the UPS operates in back-up mode.
Note! During the self-test, the UPS briefly operates on- battery backup power (the on-battery LED comes on). If the UPS passes
the self -test, it returns to on-line operation. If the UPS fails the self-test, it immediately returns to on-line operation and lights the replace battery LED. The loads are not affected. Recharge the battery overnight and perform the self- test again. If the replace battery LED is still on, the battery will need to replaced.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Oct 28, 2007
  • Vikram Kumar Thumu
    Vikram Kumar Thumu Oct 28, 2007
    Yes, if you are done with all points that  I covered. Then it confirms that this is an issue with fault with UPS, please contact UPS Manufacturer on this issue.
Not working
Here is a link for the batteries . And look in the yellow pages any computer repair shop should do fine.
http://www.batterysharks.com/Belkin-F6C800-UNV-p/F6C800-UNV_UPS12-7_x2.htm?gclid=CLWpnJeZrbwCFelxOgodOjMA4A
Feb 02, 2014 | Belkin (F6C800-UNV-PL) UPS System
I use a Belkin Surge Protector UPS 600VA, and run Win 7 64 bits. In "System Configuration", "Services" tab, Belkin APmonitor is stopped, and Belkin APMRMI is running. Nothing shows on...
2 scenarios will either play out at the end of the day:
1. During power outage, your UPS will continue to supply backup power for the number of minutes.it is built/designed to do for your PC after which it shuts down and your PC due to lack of power shuts down too.
2. if you've programmed your PC to shut down after say a short period it idles, your PC will shut down even though your UPS is still fully operational.
A third approach is to sync the situation/scenario you envisage by powering off your UPS power supply at the mains/wall receptacle.
Watch what happens next by leaving your PC idle but still connected to the UPS still powered on (but without the mains power supply to it)
Oct 06, 2017 | Computers & Internet
How do i connect my ups to my pc
Connect your PC power plug to the UPS, connect the UPS to the mains. Connect the usb lead from the UPS to your PC. Install the software on your PC. When you lose mains power the UPS will keep your PC alive long enough for an ordered shutdown.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 19, 2011 | Belkin (F6C800-UNV-PL) UPS System
I have a F6C800 and replaced the bateries. It seems to provide surge protection power through the 2 outlets but does not provide power through the Backup outlets. The monitoring software also does not...
OK - I'll ask the simple question first, so don't think I'm being crappy...
When you hooked the wires back up to the batteries that were replaced, did you hook them back up as they originally were? (I ran into this problem myself earlier today. I put one of the batteries in upside down and didn't have them hooked up correctly.)
Red terminal on the front battery goes to the black terminal on the back battery, then the black terminal on the first battery goes to the circuit board. Red terminal on the back battery goes to the power supply.
Hope that helps. It sure is a pain the change these batteries out.
Nov 29, 2010 | Belkin (F6C800-UNV-PL) UPS System
I want to connect a UPs to my computer and I don't which cable goes to a system unit or the monitor.Please show me the clip
shut down the comp and the ups
unplug the cable from the comp and plug it in to the ups i/p
take the iec male to female cable that came with the ups and plug male into ups o/p and then female into your comp
turn on ups then turn on comp
thats it
hope this helps
thanks for using FixYa
Sep 19, 2010 | Belkin (F6C800-UNV-PL) UPS System
How to connect ups to a computer?
You have output sockets at the back of your UPS. Connect your PC power input from one of these outlets and switch the ups on.
Aug 14, 2010 | Belkin (F6C800-UNV-PL) UPS System
I recently purchased a used Belkin F6C800-UNV UPS, and discovered it had bad batteries. I replaced both batteries, and charged the replacement batteries overnight. The UPS appears to be working correctly,...
This is normal in some lower end UPS's, the voltage can swing quite a bit, a drop of 40 seems like quite a bit but it's out of the question. It will also adapt to what is plugged in yes. Ultimately to test you would want to try it with something like an actual PC plugged in and make sure it stays running. I'd say otherwise it sounds normal to me.
Jul 10, 2009 | Belkin (F6C800-UNV-PL) UPS System
File transfer:old computer to new
If your UPS has both a Serial and USB port uallly only one may be used - since this is generally ment to go to a server to signal a shut down is required to the operating system. if you have both PC's on the LAN use one as the "server" since the UPS utility will allow you to send commands to shut down other PC's that are sharing your UPS on your LAN.
Dec 11, 2007 | Belkin (F6C800-UNV-PL) UPS System
Belkin Battery Backup w/Surge Protection
if this is new i suggest contacting belkin support they are very good. if not new then perhaps you can obtain new licence from belkin
Dec 02, 2007 | Belkin (F6C800-UNV-PL) UPS System
Belkin (F6C800-UNV-PL) UPS System Logo
943 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
