PAPER SWITCHING PROBLEM FROM FRONT TRACTOR
SOURCE: epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
SOURCE: Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Keep me posted if you have inquiries, thanks!
SOURCE: Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
SOURCE: error 07 ,turn off Printer on dfx 9000
Timing fence could be faulty or dusty. Clean it and test if that fails replace it.
SOURCE: error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
