your convergence power supply blew a fuse & probably one if not both of the STK ics. Normally when this happens the short takes out the low value resistors connected to the ics. it is common practice in the shop to replace both STKs and resistors
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-51HX42 51 in.
Panasonic PT-51HX42 51 in. Rear Projection Television
Hello my name is Troy and I read a posting of yours about repairing panasonic pt-51hx42 model tv and...
(More)
Hello my name is Troy and I read a posting of yours about repairing panasonic pt-51hx42 model tv and was hoping you might be able to help me. When i push the power button the set turns on for a few seconds then turns off and the power light flashes three times. Its seems like a common problem from what I've read, but no one has posted the actual problem and or step by step instructions on how to repair which is something i think i can do if i had the info... so if you have any advice it would be most appreciated
i was attemptin to remove the main board from the tv to replace the convergence chips, and pulled on...
(More)
i was attemptin to remove the main board from the tv to replace the convergence chips, and pulled on a red wire that appears to be connected to a "distributor cap looking thing" that then broke. it appears that it was soldered deep incide the part. What is this and is it bad that that i did this, will it work by just re-securing it in the "distributor cap thingy" or did I just ruin the tv to the point its not salavageable, or is this part i broke replaceable and what is it called?
i have a panasonic pt-51hx42 and when you turn it on after about 3 seconds it turns itself back off...
(More)
I HAVE A PANASONIC PT-51HX42 AND WHEN YOU TURN IT ON AFTER ABOUT 3 SECONDS IT TURNS ITSELF BACK OFF AND YOU HAVE TO UNPLUG IT AND PLUG IT BACK IN TO GET IT TO TURN ON AGAIN
I have a panisonic pt4743g when I turned it on it sounded like it was comming on, but then just when...
(More)
I have a panisonic pt4743g when I turned it on it sounded like it was comming on, but then just when black. No sound no picture. The power light flashes three times then stops for about 10 second then flashes again three times the stops fpr 10 seconds. Any Ideas?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
