Question about Logitech 350 (980374-0914) Headset
Left headphone does not work properly
My left headphone rarely works, the only time it might work is if the headset is tilted in a certain position, usually if i just tilt my head to the left the headphone will work to a certain extent.  I do not know why this started happening. I took good care of the headphones, but one day this problem seemed to just randomly start.
  • 3 more comments
  • aixelsyd Oct 28, 2007
    Thank you very much for the the reply.
    I have not tried your suggestion yet, could you please give more information.
    The cable that goes directly into this headset is very thin(and becomes gnarled easily), but further down the cable there is a volume and mute controller that has a much thicker cable going into it.  I have no experience with this so please be descriptive.
    Thanks again.
  • Anonymous Nov 16, 2007
    I cannot hear any audio from the left side of my headset. ANy solutions?
  • Anonymous Dec 06, 2007
    I have the same problem but instead of the left one my right speaker on these headphones do not work. Tilting head about 45 degrees will make it work again.
  • barktiger Dec 06, 2008
    every tome i plug in my head phone the right one works but nothe left one. The right one works just fine.CAN SOMEEONE PLEASE HELP ME!
  • Flame125 Mar 05, 2009
    The left stereo doesnt work.. I think it has something to do with the wires inside of the right headphone piece.. There is another post that tells you how to take it apart. Im currently trying to fix it now.
    Brigadier General:
  • 6,966 Answers
Based on your post/description, it would seem that the cable of your head phone developed an open circuit somewhere. I would assume it is pretty near the headset itself. On most occasion, it is at the very entry point where the cable goes into the headset.
Normal repair would involve opening the side casing where the cable enters the headset, cutting the cable about 3 inches from entry point, strip exposing the three or 4 wires and reconnecting inside the stripped ends. Effectively what you have done is trim the cable a bit shorter eliminating hopefully the intermittent section.
Hope this be of help/idea, Post back how things turned out or should you need additional information.
Good l;uck and kind regards.
Posted on Oct 28, 2007
How can i fix the headphone jack on my iriver H10 6GB?
What i would recommend you to do is to use a different headphone jack....I am a DJ also and certain headset doesnt work properly when you have it all way..try a different one and let me know the outcome..
Thank You
**Please rate accordingly***
Jan 30, 2008 | iRiver H10 MP3 Player
Left speaker on my Koss SB45 Headset isn't working unless I tilt to the right or turn around.
Have a look at my tip on headphone problems. Just click my user name to find it.
Jan 08, 2012 | Koss SB45 Headphones
IRiver E100 headphone jack
The connector is defective - probably just wear and tear
Aug 15, 2017 | iRiver E100 Digital Media Player
The left headphone on my Plantronics Gamecom Pro 1 headset seems to not be working. Occassionally upon plugging it back in (it is USB), both headphones will work, but then the left one seems to cut out...
Most headphones are sealed by clips located underneath the foam (on the ear things). Stick a paperclip or xacto knife into the hole to unlatch the clips and then pry it outward. However, check the cable for any obvious breaks before disassembling your headphones.
Dec 31, 2010 | Plantronics GameCom Pro 1 Headset
The sound comes and goes from right part of headset
The left/right problem could be a bad connection on the red/white XBOX cables. Check to see that they're plugged in properly and not loose. You can also try plugging an MP3 player into the red/white jacks to see if the problem is with the headset or the XBOX. If it works ok with your MP3 player, then the headset is working fine.
You can get a new headset controller cable on our web site. Click on Replacement Parts in the left menu for the headset model you own (X1, X3, or X4).
Jul 04, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
My microphone will not work, and my computer won't recognize!
Common problem with this headset.
In short, the wiring for the mic in the left earpiece is quite shoddy, and over time will be worn away by changing the mic position or come loose with minimal effort.
Have had a over a dozen of these fail in our internet cafe due to this issue after a couple of months use.
May 31, 2009 | Genius HS-04SU Headset
Sound in left headphone only sometimes works
you can warranty them on there website. they will probably send you a new pair.
May 07, 2009 | Skull Candy SC-INK'D/Blk Consumer...
How to take apart
I figured out how to remove the headphone clip without causing cosmetic damage to the headphone casing. Unfortunately for me, this was after I had scratched up the casing already. Anyway, to avoid the cosmetic damage, use some kind of plastic tool, like a plastic spoon. After pulling off the headphone cushion, you will see the aforementioned 4 slots. Carefully slip the handle end of the spoon underneath one of the slots(not through them), and apply gentle pressure toward the center of the speaker. Do this for each of the 4 slots, and the tabs should easily come loose. Hope that helps.As for figuring out how to get the headphone to work, I'm waiting for that solution myself. The right headphone is out, but the left one works, none of the wires are loose, so the damage must be from my nephew being careless with the headset cable, and probably tugging on it once too often. Don't let your 15 year olds use your headsets, if they tend to be clumsy :)
Mar 22, 2008 | Logitech 350 (980374-0914) Headset
Logitech 350 (980374-0914) Headset Logo
1,723 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
