Question about Toshiba 24AF41 24" TV
Horizontal Lines Across Screen of Toshiba 24AF41 I have several horizontal lines across my screen about 5 inches down from the top
  • JohnJohn55 Oct 31, 2007
    Thanks so much for your input....if I can fix a cap on my guitar amp I should be able to do it on the tv....I'll follow up when I try your advice
  • Anonymous Nov 08, 2008
    Did you find which cap was the culprit? I am having the same problem
  • 93 Answers
Check for a bad capacitor in the horizantol section
Posted on Oct 29, 2007
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
Why has my sanyo flat screen television only got coloured horizontal lines across the screen?
That might be an issue with the TVs picture tube if it was not one of the LED or LCD TVs. Please get a technician changed it. If it was any one of the LCD or LED TVs, then it would be more expensive than you expect.
Jul 20, 2014 | Sanyo Televison & Video
Sony FD Trinitron WEGA KV27FS100 horizontal lines across top part of screen
Check and replace all electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them to replace. Replace all at one time. The fault you describes here is technically known as 'vertical retrace lines'. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Sometimes, you might get some more details from there.
Oct 13, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Horizontal lines across the top of the screen
it is a fault in one of the capacitors in the vertical part of the schematics it is 33uf -160 volts capacitor , dry out and need to replace refer to qualified , regards , plz don't forget to rate thx
May 02, 2007 | Toshiba 27A44 27" TV
Toshiba 24AF41 24" TV Logo
269 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
