Question about Hitachi 42V710 42" Rear Projection HDTV
Light Blue Circle in Center of the Screen
My Hitach 42V4210 has a light blue circle in the center of the picture.  It is most apparent on blue and green backgrounds.  If I am watching a black and white movie, you can always see a differently shaded circle are in the middle of the picture.  Is it the bulb or do I have another problem?  Thanks.
42V710 is a DLP rear projection TV does it have CRT's ???
Posted on Dec 20, 2007
    Genius:
  • 1,139 Answers
Hello BruceD,
What you may have is a magnetism problem. I would suggest that you try deguassing the CRTs first before looking into replacing the CRTs. You can have a TV technician perform this for about $50.00 - $60.00.
Thank you,
Shuttle83
Posted on Oct 28, 2007
Sony Wega projection tv with cirlce emblazened in center of scree
The clown face you see is the cap that the repair man (clown) did not remove from the new optical block he/she installed. The optical Block will have to be either removed from the TV so that the cap can be removed OR a crafty individual could take the screws out from around the screen frame and mirror cover and pop it out using a broom handle with a wad of duck tape on the end. In any case, this is mistake that can easily happen (I have done it), but the picture should have been verified before it was returned to you. Make them fix it in your home. I hope this was helpful, best wishes.
May 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a light blue circle on the right center of screen does that mean the light engine is failing
yes the light engine is bad so call hitachi and some times they will pay for the light engine even out of warranty defect on there part. good luck
Dec 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
BLUE CIRCLE ON THE LEFT SIDE OF THE SCREEN ON SONY KF-50WE610.
This is a problem with the light engine, try contacting sony 800-222-7669 because there are some models that they extended the warranty on the light engine :)
May 25, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Blue circle in the center of picture
I need to know what color you got the circle in because one of your lamps went out and needs to be repaired this circle is only going to get bigger an bigger and shall i go on? Easy fix buy the new one and have it put in around $90 bucks plus labor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Hitachi 46F500 46" Rear Projection...
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sansa e260 takes 15 mins turning on.
once the blue circle is there, you just need to wait, it'll turn on
if not, take it to a best buy
May 05, 2008 | SanDisk Sansa e260 MP3 Player
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Hitachi 42V710 42" Rear Projection HDTV Logo
322 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
