-   I have a jazz dv179, how do i charge the battery, there is no place to plug it in, just a plug in for earphones and a usb ...So how do i charge it..my email is pete_pat@rogers.com
-   Guest
Dec 31, 2008
-   so how do we charge these?
-   Guest
Mar 07, 2008
-   I want to know how to charge the battery, i have an adapter but iI can not see anywhere to plug it on the camera, do I have to buy something else, the adapter comes with the camera but want can I do whit it if there no hold to put it.-   helpsylvie
Feb 15, 2008
-   hey, people. whats going on ,this is out to all the people having problems with their Jazz 179... open up the battery and check if it is in the right way...hope i helped you!
PS. my Jazz 179 takes to one to two hours to charge at the max!
you might of put the battery in the wrong way battery mine runs for hours and charges in 1 hour
Was this helpful?
Yes
No
Solution #4
posted on Dec 29, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have had mine charging for 3 days now, and it's not working yet
Solution #5
posted on Dec 16, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my baterie charges fine,its the webcam option that dosnt work
Solution #6
posted on Feb 22, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
how long is the built in memory supposed to last without a sd card
Solution #7
posted on May 03, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
To guest, you have to plug in the camera firstly then the light should go red at the top once it stops flashing red you press the record/play button once and the light should go green, then you should be able to use it as a web cam
Solution #8
posted on Oct 30, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
when the red light stops blinking, the battery is then fully charged
Solution #9
posted on Dec 26, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my jazz dv179 does not have lights when it is plugged in to charge. why?
Also, the Jazz Camera comes with a NP-60 battery with 3.7V and 1050mAH. You can purchase a stronger battery on E-Bay for dirt cheap. Still NP60 and 3.7V but 1400mAH. This newer battery will take about 10-15 minutes longer to charge but will give you approx. 1/2 hour more video time.
My camera power turns on when flip screen opens. At 3/4 open the camera powers on every time but and...
(More)
My camera power turns on when flip screen opens. At 3/4 open the camera powers on every time but and if you continue to open the flip screen really gently to full open it may stay but most likely the camera will shut off. The only way to keep the power on is to keep the flip screen in the 3/4 position, what could be wrong - it is almost like the connection is faulty
jazz dv179 camera flip screen connector needs a new ribbon cable. where can I find the part number...
(More)
jazz dv179 camera flip screen connector needs a new ribbon cable. where can I find the part number or get a new part
Documentation does not indicate battery charge time. Approximate timing would be helpful versus 'when the blinking stops'. Won this camera at an event - how is the performance of the unit - any comments?
Comment by Guest, posted on Nov 02, 2007
approximatey how many hours are needed to fully charge the battery,and don't reply by saying when the red light goes off.
