Question about Hitachi 65F59 65" HDTV
Pictue is dark as hell
Hey i have a 65F59 hitachi hd tv   and i reset the factory settings  on it and the picture is dark as hell
ever
no bright colors show up and  seems like everything is in a shadow
what could the possible problem be?
    President:
  • 4,402 Answers
Use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
Hitachi 65f59 65 TV keeps shutting off
This set uses a number of green L.E.D.'s inside which are tied to different voltages---if you can watch them when set shuts off you are looking for one that goes out either quickly or after the others--points to area (voltage) where problem may be.
Other visual indications are screen changes red, green, blue right at shutdown and sound and brightness then both vanish=shutdown circuit being triggered to protect the set.
May 15, 2012 | Hitachi Televison & Video
The screen is dark
If it's a projection tv, your bulb is about to die.
Apr 24, 2012 | Hitachi 65F59 65" HDTV
I have a Hitachi 50v500 tv and the picture has tuned bright white almost like a flash. I stillhave some color but not all. Do you know what the problem could be?.
Go into the settings and adjust the picture, turn the brightness and most likely the contrast down, or there should be a reset button to change it back to factory settings.
Mar 28, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Get sound no picture lots of colors flashing
What king of TV? "DLP" your DMD board. Just throw tv out. Expensive, $300-800 and a SOB to install. If a LCD it is your T-CON/LCD control
board. Somewhat simple to install. Runs about $60-175 depends on brand and size of tv. It over heats and causes weird colors"floresent colors,colored bars,or the sereen to go hay-wire plad/stripes go bright/dark. Try Shop Jimmy for used/recon. parts. Hope this info helps. Todd
Jan 01, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
PICTURE NOT AS BRIGHT AS I WANT HAVE TRIED ALL . TV IS HD REAR PROJECTION . I HAVE TRIED ALL AJUSTMENTS,COLOR,TINT,FORMAT,SHARPNESS, BRIGHTNESS ETC. LAMP ONLY ONE YEAR OLD.
Unfortunately there are 2 IC's and a capacitor that can cause this set to be really dark. Without proper troubleshooting it is impossible to diagnose. Have a shop check it out for you. Thanks
Oct 27, 2009 | Hitachi 50UX58K 50" Rear Projection...
Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Jan 15, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 1080i Plasma TV
In the video setting go down to reset. You will only need minor adjustment after a reset.
chrislorrie@sbcglobal.net
Nov 09, 2007 | Hitachi Televison & Video
Hitachi 65F59 65" HDTV Logo
268 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
