Question about Sharp Aquos LC-32D40U Television
Tv codes In trying to help my daughter with a direct tv problem, I recoded her Sharp Aquos tv & direct tv with new codes using an older Sony universal remote. Now nothing works. It went to analog cable & the direct tv box doesn't work at all when before it worked fine from the box before (the reason we were programming the universal remote was because the direct tv remote was broken.) Do you have any suggestions?
  • Anonymous Dec 28, 2007
    I JUST BOUGHT A MEMOREX WIDESCREEN LCD HDTV,I ALSO HAVE DIRECT TVBUT I CANT GET THE NEW TV REMOTE TO TURN ON MY TV,ONLY THE DIRECT TV REMOTE WILL TURN IT ON.HOW TO I GET THE CODE FOR MY REMOTE CONTROL ON MY NEW TV?
    IT HAS THE MODEL NO MLT3221.
    PLEASE HELP
    MY EMAIL ADDRESS IS MOTORCYCLEBABEONE@YAHOO.COM
  • helen039 Jan 23, 2008
    Yes I do have the same problem but intead of Direct TV I have Dish Network but exactly the same problem with my memorex mlt3221.
    Top Expert:
  • Sharp Master
  • 52,931 Answers
YES throw that old sony remote away .
Posted on Nov 27, 2017
  • 4234 Answers
SOURCE: analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Posted on Sep 23, 2008
SOURCE: Sharp Aquos LCD only shows analog
You will prob. have to order a new original remote.  It has the options on it to change from analog to digital.  I don't believe there are any options in the menu or buttons on the tv that switch between the two.
Posted on Oct 13, 2008
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Mar 01, 2009
  • 21 Answers
SOURCE: i have a sharp aquos and an older mac mini.
Actually, if your mac has the Mini Displayport connector, there is a $37 adapter you can use:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10428&cs_id=1042802&p_id=5969&seq=1&format=2
It will tie up one of your USB ports as well, which it uses for the audio signal.
Posted on Nov 04, 2009
I NEED THE 4 DIGIT CODE FOR A SHARP LCD TV ON THE GE UNIVERSAL REMOTE CONTROL
0286,0261. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need remote for sharp aquos LC42XD1E
Setup codes to Sharp brand TVs with universal remote control are 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122. Just buy a remote control, which has setup codes to Sharp TV. You can get this iformation from the attached specification sheet with each universal remote control If you wish to get more details to different other brand remote controls, check this link.
Feb 06, 2013 | Sharp Aquos LC42XD1E 42 in. LCD TV
I have a new sharp aquos tv LC 60LE633U. Remote is broken but have a universal Phillips remote anyone know the code ? Help please
Hello
Three digit universal remote codes for Sharp tV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 28, 2012 | Sharp Televison & Video
Remote Stopped Working
It is possible the IR sensor is bad. Most of the time if it is a remote issue, the light on the remote will not light up. Does the remote that came with tv still control any functions? I would try the remote that came with the tv, and then go from there, but it sounds like your IR sensor has gone out on you.
Mar 31, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No remote to my sharp tv LC-32SB24U need codes to program my remote...
I have a Sharp LC-32SB24U TV, I need the universal code for my universal remote.
Jan 16, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I just purchased a used Sharp Aquos 32 LCD model # LC-C3234U without the remote. I have Direct TV and the television needs to be on channel 3. With the buttons on the television the closest I can get is...
Try encompassparts.com and see if they have the original remote. The channels you are getting are digital channels. You are going to have to get it back to analog channels.
Oct 12, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
What is the philip universal control code for sharp aquos lcd monitors?
try these
002 013 014 111 502 712 812 813 913 918
if none of them work you will have to try all codes one by one.
Check this link out for more info
http://www.universal-remote.net/philipsmagnavox.html
Good Luck
Jul 29, 2009 | Sharp Aquos LC-19D45U 19 in. LCD TV
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
576 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
