Question about Brother HL-2070N Laser Printer
Printer prints crooked (8.5 x 11 from paper tray)
Our Brother HL-2070N jammed on us just once because it was turned off in an effort to stop an erroneous long print job that was still in its que.  Ever since the jam was cleared, it prints crooked on standard paper out of the paper tray.  Looking at a documents printed after the incident, there is a noticeable slant from left to right across the document that slants downward 1/4".  We have tried removing the toner cartridge a few times hoping that this would resolve the issue, but we have had no success thus far.  Any suggestions?  Thanks.
  • 2 more comments
  • BTC1984 Nov 25, 2008
    same problem. prints crooked, off just 1/4 inch
  • Anonymous Feb 19, 2009
    After changing my last toner cartridge, my printer prints crooked as well. It does it from the paper tray as well as from the manual feed. I suspect something is pulling in the paper stronger on one side vs. the other side.
  • Anonymous Mar 05, 2009
    Has anybody found a resolution for this? Mine just started doing the same thing. Everything looks fine. The paper guides appear locked in. I have tried reseating the cartridge but prints still have a noticeable slant
  • Anonymous Mar 24, 2014
    printing labels for the MP tray, pull the first few labels fine but then stops and starts pulling from tray 1. I have 100+ labels to print. Is there a fix for this issue?
  • Brother Master
  • 1,113 Answers
Check that the paper guides on paper cassette are hard up against paper edges
Posted on Oct 28, 2007
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Paper jammed in my 2070N printer & I don't know how to remove it
That machine doesn't have a release lever, you need to pull the paper out, as straight as possible trying not to tear it. There probably is a problem with your fuser, and it will need to be replaced. Even getting the paper out, it will probably jam again on the next print.
Jul 22, 2009 | Brother HL-2070N Printer
Brother hl 2025 tn will not stop printing. went to :control panel>printer> properties>cancel all documents. then replaced paper tray hit start button & printer starts printing again. Pull out...
You have the wrong drivers or corrupt drivers on your system.Disconnect your printer and restart.uninstall your printer and download new drivers and reinstall.all should be fine
Jun 25, 2009 | Brother HL-2070N Laser Printer
Extra paper being fed after print job
Try a test page from the control panel, if this works properly you probably have an issue with the software of the printer. Reload the printer as if it was a brand new machine.
Jun 03, 2009 | Brother HL-2070N Laser Printer
How do I remove paper from paper jam?
To remove paper pull the paper with both hands being careful not to tear the paper . If you're unable to pull it you may need to manually rotate the gears that feed the paper through the printer
Now reset the printer by pressing the power button in on state to turn it off and restart
again thats all just take care that you remove the tray carefully
Thanks and Regards
May 12, 2009 | Brother HL-2070N Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N won't feed paper from tray
I had the same problem with 2 of the 2070N printers. Solution was that the paper tray was setting to tight against the paper pushing it tight up to the front of the tray. Back the rear support up so there is maybe 1/16 inch clearance between the paper and the end of the tray. No more feed problems.
Jun 04, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
1,210 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
