Bunn RL Coffee Maker
Problem for Bunn RL Coffee Maker
Bunn coffee maker trips the breaker
By ChiefDan on Oct 27, 2007
Recently our Bunn coffee maker suddenly started tripping the breaker as the water heats up. It will power on and the water will start to heat and then about 60 secs. into it the breaker will trip. Could this be due to the limit thermostat or the solenoid? Thanks
Same Problem
Oct 11, 2008
-   Same thing happened to us.  It was about a year old. tried multiple outlets, popped them all.   Had to buy another...-   Guest
Jun 28, 2008
-   I have commercial ST-15 Bunn and it trips the GFI after about 30 seconds.
Any recomendations?-   hsbsms
Dec 16, 2007
-   Ours does that, too. We thought it might have been the breaker, but when we moved it to another curcuit it still tripped the breaker. The coffe maker is only 1 year old and I didn't think it would die this soon!-   Myrnabahamas
Solution #1
posted on Feb 13, 2009
Not Rated)
furnoptn
Rank: Guru
Rating: 89%, 70 votes
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Was this helpful?
Yes
No
Popular Solutions for Bunn RL Coffee Maker
Questions and Unsolved Problems for Bunn RL Coffee Maker
Do you recommend Bunn RL Coffee Maker?
Answer
Answer
DeLonghi Magnifica There is water leaking from the water reservoir area of the machine. After... (More)
Answer
Leaking around frother at connection to machine. Can't locate parts want to take it to a service... (More)
Answer
water does not shut off when coffee is brewed
Answer
i push the button to brew a pot, water comes out for the pot, but is cold not hot. the thermastat up... (More)
Answer
I have had this machine without any trouble until this week. The water doesnt fill the pot.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
