Question about Compaq Presario FX700 17" CRT Monitor
Monitor sliding off screen
I have a FX500 as of ealier today the monitor was fine other then the sound dial not working.. But now its sliding off to the right and I cant find theĀ  X and the arrows to scroll down, is there any way to adjust the screen? There is nothing on the monitor to do so..
  • 68 Answers
SOURCE: Actually my compaq monitor screen working Small, I
Hello View,
Should be a simple fix, just hold the menu button in for 20 seconds, and it should unlock it.
Posted on Aug 14, 2011
0 characters
1 Points
Why is my monitor shuts down after a few minutes of use?
It sounds like its shortiung out my freind Dust is a horrible little "feind" and is not computer/electronics freindly
May 07, 2014 | ASUS VE208T 20 inch LCD Monitor
I have a Dell laptop whose screen died sometime ago. I now have a Dell E193FP monitor connected and it has worked fine until today. Now I have a black screen and an amber light. Pressing other buttons...
Sounds to me it could be a burnt or illegible ram memory card in your laptop, try taking one of them off, or switching one of them to the other slot just to troubleshoot.
Hope this helps you.
Jan 07, 2014 | Samsung SyncMaster 152N 15" LCD Monitor
No power in the Monitor
Sounds like a fairly drastic fault, possibly in the power supply section. Probably not worth fixing with the cost of new LCD screens, but maybe worth asking at a local repair place.
Apr 06, 2010 | AOC 7F 17" CRT Monitor
Dell monitor problem
Try pressing Fn + F8 keys to toggle the screen image.
Nov 30, 2008 | Dell E176FP 17" LCD Monitor
Poor screen quality
re install your dell video card driver
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
Monitor black
Try looking at the Monitors Plug, Look directly into the Plug, you should see 15 small pins inside the plug.
Sometimes one or two of these pins get bent over and no longer makes contact. If you do see a pin than is not pointing straight out like the reset, the best thing to do is to use a small pair of needle nose pliers to gently straighten the pin. Be very careful becouse once a pin is bent it can break easily.
Oct 18, 2008 | Computer Monitors
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
Compaq Presario FX700 17" CRT Monitor Logo
27 people viewed this question
Top Compaq Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Ricky Ostrom
Ricky Ostrom
Are you a Compaq Computer Monitor Expert? Answer questions, earn points and help others
