Question about Kirby G4 Bagged Upright Vacuum
Rainbow e-series not working
How do i open the top cover to get to the switch?  basic unit serial # 1548499,  want to check electrical connection with-in the switch and power unit.  thank you..........
  • Anonymous Dec 27, 2007
    How do I replace the power switch?
    Do have to remove the fan?
    Is there a sequence to follow?
    I have the Kirby Vacuum Generation 4 apart and on my bench.
    Thanks
    Ron
  • 357 Answers
Pop off the clear plastic side pieces and the 4 screws are located underneath. I suggest checking the carbon brushes and armature, as these are the parts of the e series that are most generally in need of replacement.
Marci
Posted on Dec 27, 2007
Where can I get a step-by-step procedure for rewiring?
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
Nov 04, 2015 | Rainbow E series Canister Wet/Dry Vacuum
How to fix rainbow vacuum e series on/off switch
You can find a walkthrough on disassembling your E series one speed Rainbow here.Rainbow E Series Motor Unit if you go to step 9 that gets you to the switch and how to unwire it.
GoodVac.com
800-775-6586
May 28, 2014 | Rainbow 75th Anniversary Canister Vacuum
Electric hose on rainbow not working
Be sure to have a solid connection and that you hear two clicks when connecting your electric hose to the front of the main unit. If this connection is not solid, then the receptacles can not make contact. Try bypassing the hose and plug your power nozzle directly into the front of the main unit to confirm that the hose is the issue.
RainVac
www.rainvac.com
800-523-0510
Aug 06, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum e series works on low but not on high
It is either the switch or the controller. Call us and we can see if it is still covered under your warranty.
RainVac
www.rainvac.com
Jul 21, 2012 | Rainbow E series Canister Wet/Dry Vacuum
The power cord is split near the base unit
There are 2 screws on each side of the top cover of the Rainbow ‘E’ series vacuum cleaners located behind the decal windows. To get to the screws; use a non-scratching tool such as a plastic putty knife and pry out a corner of the plastic window, carefully pull out the plastic window and decal and remove the 2 screws. Repeat this process for both windows and then just lift up the top cover to expose the inside.
May 15, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
How to remove an old Rainbow E Series Cooling Filter
The motor filter is under the top cover.
Caution: Be sure your vacuum is unplugged from the electrical outlet before proceeding! There are 2 screws on each side of the top cover of the Rainbow ‘E’ series vacuum cleaners located behind the decals. To get to the screws; use a non-scratching tool such as a plastic putty knife and pry out a corner of the plastic window, carefully pull out the plastic window and decal and remove the 2 screws. Repeat this process for both windows and then just lift up the top cover to expose the inside.
Oct 25, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Won't turn on
If there was a smell like something plastic burning it may be that something just actually burned. It does not have to smoke like a chimney (sometimes it does though - depends what is burning)... If there were no strange noises and it did not seem to run any different than usually - most likely the motor is still fine. I would inspect the cord really carefully but to do any more than that you would have to open the unit and inspect everything else.
If you chose to do so – open the Rainbow and hook up the motor directly to a power supply (hold on to the unit as it will move while starting) – if it runs then problem is in wiring. Test the cord with a tester or bulb, then the switch (or 2 switches if this is e-series Rainbow). Make sure all wires are intact. There is not much to test so you will get it done and find the problem quick.
This is messing with electricity and subjecting you fingers to potential hazard by exposing working motor so do it at your own risk and be very careful and if anything goes wrong do not blame me :-)
Aug 31, 2008 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow E series power switch doesn't work
To get access you need to remove the plastic side cover panels. To remove these, I found the easiest way was to use a small flat screw driver, leverage it under the pastic in the centre at the 'cord end' and lift carefully. There are two lugs at the top and one at the bottom. The plastic panel will 'bow' a little, but with care, it will pop off. The gold looking vents underneath are just a 'facade'. By removing the side plastic panels they will expose three screws either side. Undo these and the top will half of the cleaner will lift off. Good luck!
Jun 25, 2006 | Rainbow E series Canister Wet/Dry Vacuum
Kirby G4 Bagged Upright Vacuum Logo
46 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
