Question about Kenwood KAC-X650D Car Audio Amplifier
AMP FOR SUB SHUTS OFF SOMETIMES
  • ANYONE HAVE ANY IDEAS.. MY AMP FOR THE SUB SHUTS OFF SOMETIMES, THEN I SHUT OFF THE RADIO AND IT SEEMS TO RESET ITSELF AND WORKS FINE.CAN THIS BE THE END OF MY SUB'S LIFELINE?
  • MY OTHER AMP FOR THE INTERIOR SPEAKERS WORKS FINE AND REMAINS ON.
  • THIS ONLY HAPPENS PERIODICALLY NOT ALL THE TIME.
How do i keep my amp from overheating?
Posted on Apr 25, 2008
    Problem Solver:
  • 5 Answers
IS the unit overheating?
Posted on Apr 14, 2008
    Problem Solver:
  • 30 Answers
Your system is not connected right take it all out and put it all bk in
Posted on Oct 27, 2007
My amp stays on when i shut my car off.. .any ideas?
That means you didn't put your signal switch in right. The signal switch should be connected to your radio. So when your car shuts off it sends a signal to your radio to shut off then your radio sends a signal for your amp to shut off.
Mar 06, 2010 | Alpine MRD-M1000 Car Audio Amplifier
HTR-5890 receiver keeps shutting down
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Yamaha HTR-5890 Receiver
Front panel turns off
Have you performed a FULL reset on the TS-2000?
To perform a full reset:
With the power off press and hold down the A=B button and with the other hand turn on the TS-2000.
After that you will have to press the A=B one more time. The radio will reset itself,
and the display will show 14.000 MHz in the main band, and 144.000 MHz in the sub band.
Please let me know if it worked for you.
Tommy
KG4TDM @ arrl .net
Sep 12, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
I have a PHOENIX GOLD RYVAL V1502 amplifier and trying to hook it up at 2 ohms as it describes it can be 450watts x2 at 2 ohms running wires from bridged positive and negative to the first sub then two...
Hello mgonzalez390,
It sounds like the amp/subs impedance is not matched. According to the published specifications for the V1502 amp, it is only stable in bridged mode down to 4ohms, not 2ohms. You need to get the final impedance that the amp sees up to at least 4ohms or it will continue to shut down and eventually fail completely.
If your subs are dual voice coil and can be rewired so that each sub has an impedance of 8ohms, then you can safely parallel them to the amp like you have described. If they are single 4ohm voice coils, then you have 2 choices. Connect one sub to each channel or if you want to bridge the channels, then wire the subs in series, not in parallel. Wire the positive bridged terminal from the amp to the first sub positive, connect a jumper from the negative of that sub to positive on the other sub, and then the negative from that sub back to the negative bridged terminal on the amp. This wiring results in an 8ohm load to the amp and it should work OK without shutting down. But the power to each sub will actually be less than if you wire them separately to each channel.
Hope this helps.
Jul 08, 2009 | Car Audio & Video
Subs on stock radio
chev stock radio does not have extra plug in for sub. to run your sub, im assumed you also going to run an amp to it also. there are no addition plug in in the back, but that does not stop anyone if you know how to rig things. i would not recommend rig wires on your 2007. I would install a new radio before rigging that car; than add a sub. keep in mind most of GM radios come with stock amp built into the radio itself. If you cut the wires from the radio and wire it to your sub amp you will get nothing but distorted sound. anything sound goes to any amp need to be pre-amp in order to work properly. hope that help some
May 16, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Is it my amp not working?
Maybe the amp is fr the high and lows because if its bass that shukd do it but most of the time it could also be that the sub is poped
May 29, 2008 | Car Audio & Video
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Sound shuts off, sub still works
That is a common problem with this radio, for it can not go to loud without going down in volume or shutting down.
Dec 08, 2007 | Pioneer DEH-P3100 CD Player
Kenwood KAC-X650D Car Audio Amplifier Logo
167 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
