Home | PC Laptops | No CD /DVD Drive Icon
PC Laptops
Problem for Acer PC Laptops
Generic problem for all Acer PC Laptops
By ltb1948 on Jun 09, 2009
I have an Acer 9410Z Laptop. It’s less than two years old. I have tried to communicate with Acer support ( by e-mail ) but they will not respond.
This model uses the - Optiarc DVD RW AD-7530A ATA.
My DVD/CD drive stopped working. I’ve just now discovered after placing a CD disc in the drive that it spins and then nothing happens.
I clicked start computer and my DVD drive icon was not even listed - as was before.
I have a WD external drive, and after unplugging my USB plug ( after backups) - I often get a message telling me, "it is now safe to unplug my (F:) drive.
My DVD drive was (E:).
And my WD external is usually (F:) ....and still is - even with the (E:) drive icon missing.
That may be because the driver is still there, and I just accidentally erased the picture icon.
I went into my Device Manager, and tried to update my DVD driver, and was told - I have the latest driver.
Apparently, the pop-up message might have said: "it is now safe to remove the (E:) drive that I didn’t read it carefully. I must have deleted my DVD drive pictures icon by accident.
Also, when I start my applicable programs - such as NTI CD&DVD Maker, it states;
...."No supported drive detected."
Gee! ...I can’t even installed my new programs.
It was working well just a few days ago, and it has always shown in my computer dialog.
I am assuming that I erased the icon picture - but not the driver. Can’t be sure. The driver may be defective.
Can someone please tell me exactly how to make it work again?
Thanks a million times.
Best Solution
posted on Jun 09, 2009
Very Helpful)
J-K-G
Rank: Guide
Rating: 94%, 8 votes
I checked the specifications on the Acer 9410Z, and verified that it ships with Microsoft Windows Vista Home Premium.
This is actually a very common problem in Windows Vista and tends to occur for a few different reasons. One notable issue is anti-virus and anti-spyware programs that perform a system scan and remove any instances of viruses and/or malware.
Without going into too much detail there is quick fix available from Microsoft at: http://support.microsoft.com/kb/314060
Scroll down to "Fix it for me", and just click "Fix." This will run a quick installation, and then ask you to restart your computer. If it doesn't ask you, then restart it manually.
Your CD/DVD drive should now show up in My Computer, and should be recognized by all programs.
Hope this helps!
- Joshua
Comments:
Jun 09, 2009
- Regarding the comment about anti-virus/anti-spyware programs:
Programs like Trend-Micro, Kaspersky, and Spysweeper do their job correctly and remove any instances of malware they find, but for some reason this will sometimes remove your CD/DVD drive in Windows Vista. This only seems to occur in Vista as I have seen it a few times. Use the fix I provided to correct this problem.
It could also be a simple case of drive-mapping which you can check my right-clicking "My Computer" and selecting "Manage". Select "Disk Management" on the left pane and you will see all the drives installed on your computer. You will see your hard-drive, your WD external hard-drive, and hopefully your CD/DVD drive. If you see your CD/DVD drive, it may not have a letter associated with it. Simply right-click the CD/DVD drive and select "Change drive letter/path". You can then assign it another letter.
So in summary, check this first.. if you don't have a CD/DVD drive listed in disk management then just run that quick fix I gave you. Running the quick fix first will not damage your computer in any way.
Joshua
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Helpful)
kerrymaloney
Rank: Guru
Rating: 88%, 48 votes
Try going into the Administratiive tools section where you can set the letters used to identify each drive.
Start > Control Panel > Administrative Tools > Computer Management > Storage > Disk Management
Should look like below. See if your list on the bottom right shows a CDRom device, but without the E: where my D: is. If so, right-click it and change the drive letter to E:.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I currently have a Compaq CQ50-139WM laptop. I use CompuHost for doing karaoke shows and the program... (More)
Answer
Hi we need a new laptop can,t decide between a DELL INSPIRON 17 OR HP DV7 3020SA CAN YOU ADVISE... (More)
Answer
my vga connector is loose and requires resoldering. how is this done?
Answer
Note book is connecting to internet but browser is saying untitled.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
