Question about Intel DG965WH Motherboard
Wont Install I have tried to install the dvd rewrite it pwers up but the computer does not recognise it .the cable is correctly connected as my motherboard supports sata. do I need a special driver? Hope you can help. FRED
  • Anonymous Nov 27, 2007
    if it is a lg gsa-h62n then i have the same problem
  • jakebs Feb 25, 2008
    I am trying to install a lightScribe DVD-R on the same mother board. Serial ATA has been enabled in the Bios. I have confirmed the drive is powered. I have tried both Sata plugs (Sata1 and Sata2). But, I cannot get the computer to recognize the new drive.
    Is this motherboard only compatible with SATA v.1 and not with the newer SATA v.2?
    I cannot update my BIOS as a last resort because I don't have the floppy drive which is required. Can I use a cd on my functioning drive?
  • 165 Answers
If this is an intel DG965WH board:
This may sound strange, but I had similar problem.
In bios set SATA controller to IDE mode.
This uses a different driver and doesnt need Intel Matrix Storage Manager to read SATA CD/DVD drives.
This happened with 4 mobo's
Posted on Mar 31, 2008
  • Philip Markert Apr 06, 2008
    On that motherboard it is actually called "Legacy mode"
  • 4,889 Answers
Ofcourse you will need it..Get your DVD writer's brand and model...
Posted on Oct 27, 2007
  • eagle338
    eagle338 Oct 27, 2007
    I mean *get me*..
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
Laptop doesn't recognise DVD rewriter - LG
If your laptop dont recognise dvd rewriter it may be due to many reason it may either due to Ide cable or a registry issue or a hardware issue .Try following steps :
1 make sure you have correctly inserted the IDE and Power Cables. Fault of putting the IDE cable in the wrong way around make this happen.
2 Make one drive the the Master and the other the Slave, don't set both to Cable Select.
Is it not recognizing the drives in the BIOS or Windows? Try changing IDE cables?
If BIOS, have you gone into the BIOS and verified that the drives are detected? Try changing the BIOS settings for the IDE Channels from AUTO to CD_ROM. At least then, from a hardware viewpoint, you are forcing the system to recognize.
3 If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players.
4 If its a registry issue then try following steps but remember first take back up of your registry
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters....
RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
Mar 24, 2010 | Computers & Internet
I have a m2n61-ax dell board,I install a second dvd rewrite lg window will not see the drive????
if These Are IDE devices, ensure That The Jumpers Are Set To Slave And Master. If The Device still Is Not Recognised, Try Putting It On The Secondary IDE Channel, with A seperate Cable. Or Add it to The Hard-Drived Cable. If The Hard-Disk Is Jumper-Set as Slave, Move Jumper-Pin ( Small Plastic Block ) on the rear Of The Drive To Master.
Mike @ Compurepair.
Oct 16, 2009 | Dell Computers & Internet
How do i install the LG 20x external super multi- DVD rewriter to mac
connect the power chords and data chords correctly.Then install the driver software.t is given along with the dvd drive,when u buying
Aug 11, 2009 | Computers & Internet
Need to install liteon dvd rewriter
try cleaning the drive using lens cleaner, also if it is sata drive install proper drivers for that it works, gudday !!
Jan 20, 2009 | Ahead Software Nero 6.3 Reloaded (60096)...
Replacement DVD-Rom has video but no audio
You should be able to get sound thru the IDE cable (this is the same type of cable also referred to as a ribbon cable, your hard drive connects in the same way) that is connecting your drive to the motherboard. turn the pc off and unplug power and reseat this cable on both ends be careful as the pins are fragile and will break
if this doesn't fix your problem let me know and we will try anotherr solution
Sep 01, 2008 | Dell DVD-ROM for Dimension (6t903)...
Installing harddrive and dvd rewriter
change the jumper setting of dvdv to cable select or slave and remain the hd to master
Jul 16, 2008 | Intel Motherboard
Intel DG965WH Motherboard Logo
148 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
