my new wirless turbo fire 2 controller with rumble will not connect to my xbox 360 console... i' ve tried syncing it several times as instructed but no go... what am i doing wrong, it will not work with my xbox 360!
There may be a problem with the batterie connectors on the back, make sure they are clean. Also, you might buy the wireless accessory set, which comes with chargable batteries and the charging cord, with which you do not need batteries, and might bypass the problem you have.
pair the headset to the xbox by pushing the small button on the xbox and the small button on your headset once it pairs make sure the number on the headset on the headset is the same as the number on the controller otherwise you wont be able to hear or talk to people online
PLZ RATE THIS IF YOU FIND IT HELPED SOLVE YOUR SOLUTION TANKS.
The xbox 360 wirless controller has very little lag that you would not be able to notice i would suggest just getting the controller and if u want u can also get a xbox 360 controller that is wired.
chek if your ethernet cable fine or your wirless connection isnt that cood easily be the problem but other wise just run an intial set up a few times it shood work...
hi, u plug the wirless adapter to the controler in and u put the number switch to 4 and on ur controler u put the number switch to 4 ... good day ,ELi
