Question about SanDisk Sansa e250 MP3 Player
MSC MODE AND MTP MODE
I've had my mp3 player for a couple of months now and it just stopped working. Everything else on the mp3 works except for the uploading of music. When I plug in the usb and the player is in mtp mode it connect to the computer for 3 seconds then shuts off and restarts itself. When i do the same and it is in msc mode it stasys connected and when i upload music on it they go on. but when i try to play the tracks a note comes up saying bad track for every sond.....plz help
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Sansa e250 MP3 Player: won't play any music or change to any other format...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
May 16, 2010 | SanDisk Sansa e250 MP3 Player
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
May 17, 2010 | SanDisk Sansa Clip MP3 Player
Well i try to sync music to it and it stops on the first song and take forever to sync. the first song stays at 100% but does not go on to the next song at all
Just to be clear,most players require no special drivers. MSC mode will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean. MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a Thumb drive or flash drive, as a removable disk. It will assign the first available drive letter to your device, as well as one for the memory card (if it uses one and it is installed). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most computers detect the player in this mode without a problem very well and right away.
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode.
Most good MP3 players will have both of these modes at the users options.
Although not all do, so it is a good idea to check yours for these settings if you are having connection problems
NOTE: Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them. You know you have some files on your player and can not find them now, you may have to change modes so they are available. Some players in the SanDisk line up use Instead, an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
To use MSC or MTP modes go to your players settings.
These settings will vary based on player model and you might have to refer to your users Manual. Check their web site for a download in PDF form. Turn the player on, if it is not already Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc... Navigate to "Settings" on the main menu of the player. After navigating to "Settings", you should see an option that states "USB" or "USB MODE" From here we can select MSC or MTP modes (could vary based on player model) Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu Connect the player to your computer and verify it is connecting in the desired mode. It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device".
Now most players now days can and will use`MS W*ndows Media Player. You can also try to reinstall W*ndows Media Player 10 or 11 Next W*ndows has a update to fix if all else fails try this link. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
Feb 13, 2010 | SanDisk Sansa c150 MP3 Player
My MP3 stopped working. It doesn't need to be
Feb 13, 2010 | SanDisk Sansa Clip MP3 Player
Change MP3 from USB to MSC mode
Usb mode is in settings push center button choose between msc or mtp.... MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installed
Jun 27, 2009 | SanDisk Sansa e260 MP3 Player
Does not show songs that were previously synced
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??) 2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer  3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC  4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on). 5. Try other modes as well.
Jan 24, 2009 | SanDisk Sansa m240 MP3 Player
Mp3 player problem
I had this same problem.
Go to Setup on the Coby MP3 player.
Go to USB mode
Change to MSC mode if on MTP mode
Change to MTP mode if on MSC Mode.
Sep 06, 2008 | Coby MP-C741 MP3 Player
Not reading
Well, is it in MTP mode or MSC mode (menu > settings > USB)?
If it's in MTP mode, Windows Media Player should recognize it.
If it's in MSC mode, it acts like a USB thumb drive.
You should be able to add music in either mode, but I've found MSC mode simply doesn't work, though it once seemed to. Also, the Sansa m230 will not work with USB 1.1, only 2.0. Next time, I'm getting something Rockbox runs on!
Jun 30, 2008 | SanDisk Sansa m230 MP3 Player
Main load failed error
The difference is that when you have your device on MTP mode, its recognize as a Portable device...You cant modify the settings on MTP mode...When its on MSC mode, its recognize as a disk drive...thats when you can modify the drive files..to change the mode..go to menu, settings, USB mode and there you should find the MSC and MTP mode..Hope that helps
Please rate accordingly.
Thank You
Computerrep
Mar 21, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
