Question about KitchenAid KUDS01IJ - Multiple Color Dishwasher
Kitchenaid KUDS01IJBL0 Blinking Lights
I have a 6 year old Kitchenaid KUDS01IJBL0.  The unit has standing water in it (about an inch), it won't run, and the rinse and add-a-dish light are blinking.  To reset, I've tried to unplugged it for several minutes, and have also hit the cancel button with no success.  What is the problem, and is it worth repairing?
  • 4 more comments
  • KKaz Dec 18, 2007
    I have the same problem.
  • johnnypop1 Jun 12, 2008
    normal light flashes and dishwasher wont do anything.
  • liberty901 Jun 19, 2008
    I have the same problem. Tried everything that was recommended in the instruction manual and it still blinks. Nothing seems to correct the problem.
  • Anonymous Sep 03, 2008
    Add a dish light is blinking and I can't chose anything.
    I heard that it's a stuck button and I have to change my control pannel
  • lukhach Sep 18, 2008
    normal light is blinking and the machine do nothing
  • te102 Mar 07, 2009
    I have the same problem. Washer stops in the middle of the cycle and the cycle light and the number display will blink. I can do nothing except kill the power for a few minutes. I tried cleaning the control panel and door switch electrical connections and it seemed to help for a while. But, the problem is back.
  • 62 Answers
SOURCE: Blinking "rinse only" & "cancel drain" indicator lights
have you unpluged for 5-10mins? check manual for fault codes..genrally in rear. Sorta sounds like a drain problem...maybe...very common.
Posted on Jan 03, 2008
maklean
  • 1665 Answers
SOURCE: Kitchenaid dishwasher (top of the line 2000 vintage) problem
WHAT IS WRONG WITH YOUR DISHWASHER
Posted on Aug 27, 2008
  • 457 Answers
SOURCE: Greetings from Downunder, i have a
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Posted on Mar 04, 2010
SOURCE: KitchenAid 24 in. KUDI01TJ will
http://www.applianceblog.com/mainforums/kitchenaid/17513-fixed-cancel-drain-light-flashing-not-working.html
Hi it's hard to diagnose from symptoms described, but try this post and fix below i am pretty sure this may be whats happening with your unit? Please read right through to the bottom....
Posted on Jun 18, 2011
caroldon
  • 17130 Answers
SOURCE: My Kitchenaid Dishwasher...The normal light is
Remove power and keep aside for few hours, Allow the internal voltages to discharge and thus reset if there was an error on the processor.
Before the power is plugged check the door safety switch and also connections to the controller unit. check the inlet vavle and drain pump, if short is suspected remove and check.
If the fault returns then we need to suspect the processor controller board.
Posted on Oct 10, 2011
I have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go again but turns right off again. age?
That is indicative of worn motors brushes or a speed regulation circuit board problem. It is worth getting it fixed.
I just checked and my diagnosis is sound :>)
I have a kitchen aid stand mixer. model #rkt2651x. it goes - Fixya
www.fixya.com/support/t26909658-kitchen_aid_stand_mixer_model
52 mins ago - i have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go - Food Mixers question. SOLVED: Mixer goes really fast then stops
29 Dec 2007
Questions, Troubleshooting Help & Support Page 3
28 Jul 2006
More results from www.fixya.com
KitchenAid Classic Mixer K45SSWH Troubleshooting - iFixit
https://www.ifixit.com/Wiki/KitchenAid_Classic_Mixer_K45SSWH_Troubleshooting Make sure the KitchenAid Mixer is firmly plugged into a working outlet and the cord is not twisted or split. ... If your mixer still will not turn on, it might be a problem with the motor brushes. If the brushes are worn down ... The most common sign of a failing hall sensor is if your mixer increases to top speed and then shuts down. Missing: rkt2651x
Stand Mixer Shuts Off During Use - KitchenAid Product Help
producthelp.kitchenaid.com > ... > Stand Mixer Assembly and Operation Jul 12, 2017 - Once the steam has dissipated, the unit should turn on again (about 3 minutes). Resolution: If the mixer could have overheated during use let the mixer cool for at least 30 minutes and try to re-start. If you were making mashed potatoes when the mixer shut off it's possible that with excessive steam the unit ... Missing: rkt2651x
images for kitchen aid rkt2651x stand mixer goes very ...
More images for kitchen aid rkt2651x stand mixer goes very fast when turned on then shuts offReport images
FAQs - KitchenAid
https://kitchenaid.com.au/faqs Explore our range of frequently asked questions to get the very most out of your KitchenAid product. Missing: rkt2651x
[PDF]Classic Stand Mixer Speed Control - KitchenAid
https://kitchenaid.com.au/sites/.../stand_mixer_service_manual_speed_control_6-12.p... KitchenAid®. Classic Stand Mixer. Speed Control. Theory of Operation. And. Troubleshooting Guide. (revision date 6/19/2012). D. Pahl ... Mixer Does Not Shut Off page 6. Mixer Does Not Turn On page 7 ... the motor is not running (OFF) the governor ball plate is at its farthest forward position and when the motor is running at ... Missing: rkt2651x
How to Replace the Speed Sensor and Control Board on a KitchenAid ...
? 6:28
https://www.youtube.com/watch?v=41qTqTWQkMI Jan 15, 2013 - Uploaded by eReplacementParts.com
This video tutorial will show you how to replace the speed sensor and control board on a KitchenAid Pro 6 ...Missing: rkt2651x ‎turned kitchenaid rkt2651x stand mixer goes very fast when turned on then shuts...
Mar 10, 2018 | Food Mixers
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Sep 10, 2015 | KitchenAid Dishwashers
KitchenAid stops working when anything other than liquid is in the bowl..
There is a non metal gear inside the motor head that is stripped and no longer engaging the worm drive. What happens when you try to assist the turning process (try it only on stir speed, sloooowwwww) if it starts to turn and then stops again then it is the gear I spoke of. It will require tearing down the machine, cleaning all old grease, to insure that you have no ground up parts in the grease, then replace the grease gasket and gear. Hope this helps
Jan 11, 2013 | KitchenAid Professional 600 Series 6-Quart...
I have a KitchenAid mn KUDS01IJBL0 and it stopped working...no lights on controll panel...some water standing in bottom of unit...I checked to make sure it has electrical service to unit and it does...unit...
You'll have to take the door apart to access the controls. Before you do so turn the breaker to the machine off. You will also need a voltmeter with the ability to test continuity. Once you have the power off, open the door to the machine and remove the four screws across the top, and then down the sides, this should give you access to the door latch and the main control. On the control you want to located the white block looking thing located normally near the top of the door respectively. Take the wires off and test for continuity, if its there the fuse is good but more than likely it won't be and that will be the problem. The part number for that is pt# 8193762 and can be purchased at any appliance part store. Now if the fuse is good put the door together and take the kickplate, the lower part, off and then on the right side you'll see a silver box, which you need to open to see where the power comes into the machine. Sometimes the wires get to hot and melt causing a short. If this is the case fix the wires, and if its not and the fuse is good then your control board is bad and that part number is 8528172
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 07, 2012 | KitchenAid Dishwashers
I have a Kitchenaid Dishwasher about 5 years old. It has completely stopped working no lights power nothing. Water standing in the bottom. We have flipped the breaker but it doesn't seem to be an...
Removed power line from panel board # 11 as seen in appliance parts pros and shocked the board. It came to life and completed a cycle nominally. Then it died again. Tried to shock it again and sometimes it works but most times it doesn/t. Similar posts indicate a transistor failure in the board assembly. The board is easy to replace and costs about 90$. I'm replacing mine. Turn off power. Remove #15 torx screws (6) from the upper cover and lean panel forward. Remove board power . Diagram where connectors go back. Board is held in with 6 clips. Gently push clips open on one side and tilt board to remove board and ribbon cable. Reverse installation.
Sep 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
KitchenAid KUDS01IJ - Multiple Color Dishwasher Logo
1,286 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
