SOURCE: Range will not hold a consistent temperature
here is a site that might be helpfull http://forums.partselect.com/range-repair/index109.html
SOURCE: OVEN WILL NOT GET HOT THE GAS DOES NOT COME ON.
The gas regulator valve (gas shutoff valve) may have been turned-off accidentally,while cleaning or moving around unit. Just locate it, usually in the rear, under the burner top, if not, you may find it underneath, behind the bottom pull-out drawer.
SOURCE: need to take off oven door to tighten handle, gas
Great
Solution.... But now I cannot seem to get it back on.... Any Help?
SOURCE: KitchenAid KGRT607HWH6 temperture, light, error code
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
