Question about SanDisk Sansa e260 MP3 Player
New folder opened automatically - I annot delete those folders...alls songs are gone
...while I was putting new songs on my MP3 Player, then I recognized that under "music" there were automatically opened new folder named "a" "i" and "e" - I tried everything, but I cannot delete them. All songs are "gone" when I turn my MP3 Player on...but on the computer they are still there, but they don't show not under "Songlist" or "To-Go-List":
What can I do ? Please help. I only have the MP3 Player one month and it is already not working correctly. Thanks in Advance.
  • 626 Answers
Re: New folder opened automatically - I annot delete...
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Oct 31, 2007
0 characters
3 Points
How do you delete a song on the ipod touch
Open itunes up go to the folder that the song is located under then delete the song plug your ipod into the computer and itunes should automatically delete it off your ipod for you.
Jun 30, 2010 | Apple iPod touch
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
I want to delete old songs to put on new songs?
You should have gotten some form of a USB cable or way to connect the MP3. When you connect it, instead of opening the media player, open up your computer options("my computer") and open folder to view files. Then it should give you an option to delete files. (If you want to delete all of your previous media press Ctrl a to select all of your media and then press Delete)
Sep 29, 2009 | Mach Speed Trio Clip MP3 Player
Sansa e260 has no space left to write the database info. Vista and also Windows Media Player don't ''see'' any files. I can listen to all the music on the MP3 but I want to delete some and add others.
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Go to my computer scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Start over put new songs on it
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
My Sansa E260 randomly stopped working
Check and see if the songs you put on the mp3 player are a hidden file Connect to your computer open my computer goto tools on the top of the page folder options click on view Here you will see Hidden files and folder click on do not show hidden files and folders and put a check mark on hide ext....and hide protected Hit apply. Delete any songs you put on the player and start over
Apr 10, 2009 | SanDisk Sansa e260 MP3 Player
There are songs on my mp3 that i dont want..
1. Plug your Kix MP3 player into the USB port. 2. In Windows, open File Explorer (right-click Start, select Explore). 3. In File Explorer, open Insignia KIX, Fixed Storage, Music. 4. Select and delete any undesired songs and/or folders, except the Music folder.
Apr 04, 2009 | Insignia Kix MP3 Player
Cant transfer limewire music from my computer to my mp3
Once you insert the mp3 player, the computer automatically detect the device, were you can see the folder inside of your mp3, create a folder from file, new, folder.
Now open the folder where the music was downloaded usually you can see that file at my document, save/complited folder, select all the file, copy
Open the new folder (which you created) in the mp3 then paste the songs that was downloaded.
To play the music in the mp3 player, just find the folder you created.
Nov 09, 2008 | RCA TH1101 MP3 Player
Sandisk Sansa MP3 Player
If you are not able to thru Windows Media Player, you can open the device thru My Computer>Device Name (e250)>MUSIC FOLDER.
You should see the music arranged in folders by album information.Just open the folder and right click and select delete on the tracks you no longer want.
Disconnect the device and it will restart.
Best of Luck.
Nov 18, 2007 | SanDisk Sansa e200 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
Delete Songs No Music File
Jan 10, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
